Man! Some guys have all the luck. I found $20 once but an entire plane? :)
Klatt
Sent: Tuesday, September 30, 2008 7:18 PM
To: Rebel-Builders
Subject: [rebel-builders] FW: engine for sale
Here is an engine for sale from a Found aircraft at the Fort Langley airport
near Vancouver BC. The engine and plane are both working fine right now. He
just wants to change it out for a new higher hp engine so he can get better
performance on floats.
Thought it was a good deal with only 250 hours and including the prop, so I
offered that I would let you guys know here, before he posts it on
Barnstormers, and the other aviation rags.
Sent: September 30, 2008 12:10 PM
To: walter.klatt@shaw.ca
Subject: engine for sale
Hi Walter, I would like you to put the engine on your web site if possible.
That would be great! It is a Lycoming IO-540G1D5 290hp, it has 250hrs since
it was rebuilt by Valley Areo Engines in Langley. The Prop is a Hartzell
88inch 2blade and it also has 250 hrs on it. I am asking 32,000.00 for both.
They would be great for a Moose or a Super Rebel. Call me to discuss if you
like. My cell is 604-329-9044. They can be seen running or taken for a
flight as I am still using them up until I start the switch. Thanks again.
Shawn.
Yeah, there aren't that many around, but it is a certified airplane, that I
think is still being built in Ontario. Big, heavy beast, though. I think a
Moose would be a much better choice.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Craig
Walls
Sent: September 30, 2008 10:17 PM
Subject: RE: [rebel-builders] FW: engine for sale
Klatt
To: Rebel-Builders
Shawn.
Walls
Klatt
To: Rebel-Builders
Shawn.
