Bill, even though you bought the 6 bay tank option, the wing skin is
probably still full size so you have to cut it anyhow. If you are committing
to 5 bays per side I would shear the .040 tank skin down by the 11 15/16
(approx) to suit so it's easier sealing the tank with the wings skin off.
Before doing any shearing....Remember you want those tanks skins hanging off
the root rib by 1/2" to 5/8" for attaching the wing/fus fairings and off the
outboard tank rib enough for the tank skin/wing skin overlap per the manual.
lbpollock@sympatico.ca>
To: <
rebel-builders@dcsol.com>
Sent: Monday, March 14, 2005 9:01 PM
Subject: tank skins
I have decided to go 5 bays-100 gal,my tank skins are for 6 bays-120
gal.Thanks for the help on that fork in the road. I will move the heaver
main rib to outer stn 7 and the overlap of the tank skin will be on an
outer dry stn 8,does it matter about the tank skin overlapping out side
the fuel cell area??
List archives located at:
https://www.dcsol.com/login?mode=HTML
List administrator:
mike.davis@dcsol.com
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
