Planning ahead for Amphibs
David Jackson
Post by David Jackson » Sun Feb 19, 2012 4:51 pm
My intent is to initially get the airplane flying on wheels and then install a set of amphib floats. Other than the obvious float reinforcement are there any changes I should make during construction to make it easier when the time comes to install the floats. For example, what is normally done for the water rudders? Should I cut holes now to run cables later? How about mounting the hydraulics and running the lines? Should I install lines now and just cap them off?
Any suggestions would be appreciated.
Dave Jackson
Rebel 414
Find hidden words, unscramble celebrity names, or try the ultimate crossword puzzle with Live Search Games. Play now!
http://g.msn.ca/ca55/212
