[rebel-builders] Fuel Fittings
Post by Mike Kimball » Sun Feb 19, 2012 4:51 pm
I'll have to look up what those part numbers are, but if they are the little
flanged fittings with NPT threads for the fuel drain or outlets in the wing
root I do have some. I'll check when I get home tonight. I'm in Fairbanks
and you're in Alaska too aren't you?
044SR
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Craig
Walls
Sent: Wednesday, August 13, 2008 11:42 PM
Subject: [rebel-builders] Fuel Fittings
Does anyone have a spare fuel fitting they'd like to part with? I believe
W-159 is the number but I'd take a 160 as well. The part's only (only?)
$26 from MAM but they'll only fedex or ups it here and the cheapest is $70
shipping. I figure it weighs about an ounce and could be mailed in a soft
envelope. Thanks in advance. Craig
N.Smith
Post by N.Smith » Sun Feb 19, 2012 4:51 pm
Hi Craig
I am not using the brass coloured fuel fittings that came with my Elite kit.
If you're still stuck I'll check to see if they are the same and if so
you're welcome to these.
Nigel
745E
Walls
Sent: 14 August 2008 08:42
Checked by AVG - http://www.avg.com
Version: 8.0.138 / Virus Database: 270.6.3/1611 - Release Date: 14/08/2008
06:20
snowyrvr@mtaonline.net
Post by snowyrvr@mtaonline.net » Sun Feb 19, 2012 4:51 pm
Thanks, Nigel, I'm good to go now. :)
Original Message:
Date: Tue, 19 Aug 2008 10:10:34 +0100
Subject: RE: [rebel-builders] Fuel Fittings
Hi Craig
Nigel
745E
Walls
06:20
mail2web.com - Microsoft
