Grand Rapids EFIS
Gary Gustafson
Grand Rapids EFIS
Post by Gary Gustafson » Sun Feb 19, 2012 4:47 pm
I have purchased a Grand Rapids EFIS Sport for my Rebel and in
reading the instructions it says to mount the magnetometer 1)
keep the magnetometer "at least 12 inches away from any current
from any current carrying wires (such as navigation and landing
light wires) and 2) keep the magnetometer "more than 18 inches
away from ferrous metal". I was going to put the magnetometer
behind the dash but that is less than 18" from the engine mount
and less than 12 inches from current (I suspect larger loads) from
large current carrying wires.
So if anyone has a GRT Sport in their Rebel, I would like to know
where they mounted the magnetometer.
Again thanking you in advance for your reply.
Gary Gustafson - N52GG - Rebel #242
kitplane_solutions
Grand Rapids EFIS
Post by kitplane_solutions » Sun Feb 19, 2012 4:47 pm
Hi Gary
I have installed two GRT EFIS units . On one we put the magnetometer in
the wing the other was in the fuselage just behind the bagage area in the
top left corner. Both locations worked very well. I would not mount it behind
the panel as it is to close to the engine and main electrical system. you do
not need to run shielded wire as the signal is digital. I ran the wiring below
the left door sill bhind the push pull tube.
Sean
On 7/15/2008 9:55 AM, gargus@comcast.net wrote to rebel-builders:
-> I have purchased a Grand Rapids EFIS Sport for my Rebel and in
-> reading the instructions it says to mount the magnetometer 1)
-> keep the magnetometer "at least 12 inches away from any current
-> from any current carrying wires (such as navigation and landing
-> light wires) and 2) keep the magnetometer "more than 18 inches
-> away from ferrous metal". I was going to put the magnetometer
-> behind the dash but that is less than 18" from the engine mount
-> and less than 12 inches from current (I suspect larger loads) from
-> large current carrying wires.
-> So if anyone has a GRT Sport in their Rebel, I would like to know
-> where they mounted the magnetometer.
-> Again thanking you in advance for your reply.
-> Gary Gustafson - N52GG - Rebel #242
