Planning electrical wiring
Roger Cole
Post by Roger Cole » Sun Feb 19, 2012 4:38 pm
I am working on the tail cone of Elite 709. I am thinking that I
will enlarge some of the tooling holes in the bulkheads to
accommodate a rubber grommet and a 0.5-inch OD high-density
polyethylene tube for the wiring to the electric trim. I will
probably run this tube to the right of the centerline under the floor.
The cabin area looks like more of a problem because I will need a
larger tube (0.75-inch OD) to include antenna cables. Also, there
may be possible conflicts with control cables, fuel lines, and
control push rods. Then there is the issue of how to get around the
cabin carry-through structure, which supports the landing gear and
the wing. I would like to put the wiring under the floor, if
possible. How have others routed the wiring? What routing do you
recommend?
Roger Cole
Murphy Elite #709
rcole927@earthlink.net
