Could some one tell me the dimension from fire wall to instrument panel ??
Want to check on my fuselage since it is partially built by someone else.
Cant tell if it was cut back or not.
Mike#007
EOM
NOTICE - This message is the property of HATCH. It may also be confidential
and/or privileged. If you are not the intended recipient of this message
you are hereby notified that you must not disseminate, copy or take any
action with respect to it. If you have received this message in error
please notify HATCH immediately via mailto:MailAdmin@hatch.ca.
firewall distance
firewall distance
Your following message has been delivered to the 161 members of
the list murphy-rebel@dcsol.com at 19:36:36 on 7 Sep 2000.
Mike,
The distance from the forward edge of the firewall flange to aft edge of
main carry through (door post) is 22 inches when measured along the riveted
overlap between the upper corner wrap and the nose side panel. 25 inches at
the bottom corner wrap to side panel overlap. If the firewall is cut back,
these dimensions would be 3 inches less I believe ( I think it is 3 inches
even, but I've never cut one back and don't ever intend to).
Blue skies,
Sent: Wednesday, September 06, 2000 2:13 PM
Subject: firewall distance
Mike,
Blue skies,
confidentialCould some one tell me the dimension from fire wall to instrument panel ??
Mike#007
EOM
*---------------------------------------------------------------------------and/or privileged. If you are not the intended recipient of this message
*---------------------------------------------------------------------------The Murphy Rebel Builders List is for the discussion
firewall distance
Mike,
My firewall has been moved aft 3" and the panel ends cut off and rebent per
Murphy instructions. I installed the stainless steel firewall with the tabs
facing aft. I have 12.5 inches between the panel and the firewall. The
distance from the front of the door post to the firewall is `17.5 inches.
Lonnie Benson
Rebel 171
Lonnie Benson
Rebel 171
Mike#007
EOM
