Guys,
The stickers have come off of my CC-102L and 102R
rudder pedal torque tubes.
If you turn the tubes end on and look down the long
axis, one tube has the crank arm parallel to the
rudder pedal shaft. The other has an approximately 25
degree angle difference between the crank arm and the
rudder pedal arm.
Can someone please help me identify these? Can someone
also please tell me which way the sweep faces on the
arm with the 25 degrees bend? Forward or aft?
Thanks, -Jason
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
