[rebel-builders] Aluminum tube...
Bob and Olga Johnson
Post by Bob and Olga Johnson » Sun Feb 19, 2012 4:26 pm
Hi Jean: Ralph is right about extrusions being done for Murphy, however I
have been able to find round and square aluminum tubing in stock from a
place called Metal Supermarket. This is a chain of stores. You may not be
able to get the 6061-t6 with radius outside corners but other grades are
available. So I guess it is depending on your application. Bob J
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jean
Poirier
Sent: February-13-08 11:34 AM
Subject: [rebel-builders] Aluminium tube...
Someone have a source in Canada for 5/8
Jean Poirier
Post by Jean Poirier » Sun Feb 19, 2012 4:26 pm
Hum...
My plan was to use it to make a floor doubler under the rudder/brake pedal
area. May be I have an other option:
__
1- form with the box/brake or the press some "hats" __| |__
Jean
Rebel 747R
Jean Poirier
Pr
Post by Drew Dalgleish » Sun Feb 19, 2012 4:26 pm
I just made the called for .032 doubler bigger so that it's captured by the
firewall and the corner wraps / centre stiffener. It's working well so far.
At 04:13 PM 2/13/2008 -0500, you wrote:
[quote]Hum...
__
Jean
Rebel 747R
Jean Poirier
Pr
Post by Ken » Sun Feb 19, 2012 4:26 pm
__
__|
or
__ __
|___|
also works Jean. That will also hold some 1/4" plywood down if you want
a wear floor for your feet. Or just an angle |__
Even without floor mounted brake cylinders, I agree that it is probably
a good idea to install something about 1/2" high fore and aft to
stabilize the lower engine mounts.
Jean Poirier wrote:
Hum...
__
Jean
Rebel 747R
