Subaru cabin heater
LisaFly99
Subaru cabin heater
Post by LisaFly99 » Fri Feb 17, 2012 5:57 pm
To any one contemplating a Soob engine
Princess Auto 1-888-460-7989. Has an auxiliary heater fan combo that looks
like it might fit real nice? BTU 3425 CFM 60 Dim.(HxWxD) 5-1/4 x 7-1/4 x
3-1/2 Wt. 3 lb.
part# 4240007 $65 US.
Phil&Lisa Smith #460 N414D
Subaru cabin heater
Post by Bob Patterson » Fri Feb 17, 2012 5:57 pm
Sounds like the unit I bought from them for my 912 - really
good stuff ! Even includes mounting brackets ...
....bobp
-----------------------------orig.------------------------------------
3-1/2 Wt. 3 lb.
Subaru cabin heater
Post by Wayne G. O'Shea » Fri Feb 17, 2012 5:57 pm
Your following message has been delivered to the 152 members of
the list murphy-rebel@dcsol.com at 22:59:29 on 26 Aug 2000.
They were on sale for half price at the Barrie, Ontario Princess Auto this
spring to clear stock. If you are pinching pennies and don't need one
immediately, it might be worth the wait until spring again!
Sent: Saturday, August 26, 2000 10:31 PM
Subject: Re: Subaru cabin heater
....bobp
looks
x
3-1/2 Wt. 3 lb.
Joel Jacobs
Subaru cabin heater
Post by Joel Jacobs » Fri Feb 17, 2012 5:57 pm
....bobp
Does it include the heater core or is it just the fan? Does it have
separate defroster/heater ducts?
Thanks...
Joel
Rebel 416/EJ22
LisaFly99
Subaru cabin heater
In a message dated 8/28/00 9:58:17 AM Central Daylight Time, jj@netexp.net
writes:
<< Does it include the heater core or is it just the fan? Does it have
separate defroster/heater ducts? >>
Joel #416
The auxiliary heater from Princess is a heater core and fan combo ready to be
plumbed in.
Phil&Lisa Smith #460 N414D PS you would have to run your'e own defrost
duct.
But I think an after market JEEP CJ unit could work for a defuser
Subaru cabin heater
It's a complete unit - core, fan, and mounting brackets. There
is no ducting, it just blows out the front....
------------------------------orig.---------------------------------------
....bobp
Thanks...
Joel
Rebel 416/EJ22
LisaFly99
Subaru cabin heater
In a message dated 9/5/00 9:39:29 PM Central Daylight Time,
bob.patterson@canrem.com writes:
<< It's a complete unit - core, fan, and mounting brackets. There
Bob it would be real easy to use a 3" flange and some SCAT duct and an after
market Jeep CJ defusser. I say after market because it will take a 3" round
tube wile the stock takes an oval. attach the flange to a single pivot point
so it can be rotated over the heater ether fully or partially for defrost.
