Hi John,
Recommend consulting the local prop shop ... if the holes can be reamed to
1/2", they would know, and be the ones to do it.
Would NOT recommend you do anything to the prop yourself.
If possible, will you email me a picture of your amphib ...
robert@montanasky.us ... thanks in advance.
Cheers, Bob 612e
John W
Sent: Sunday, January 13, 2008 8:12 AM
Subject: [rebel-builders] prop bolt question
I have a Sensenich 76 x 56 on my Elite Amphiib I have
found a 78 x 47 Mcauley Borer prop I would like to try
out problem is the bolt hole size on the Mcauley is
3/8 and the engine is set ip for 1/2 inch. Can anybody
tell me if I can machine out the 3/8 to 1/2 to mount
the prop without compromising the same?
John W 752 E
______________________________________________________________________
______________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62s ... o8Wcj9tAcJ
Thanks Robert Agree 100% I would not consider any
mods outside of a
prop shop. Sent you some pics more later.
Rgds
John
--- Robert Andrews <robert@montanasky.us> wrote:
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch ... y=shopping
mods outside of a
Rgds
John
______________________________________________________________________Hi John,
yourself.
amphib ...
Cheers, Bob 612e
John W
have
try
anybody
John W 752 E
http://mobile.yahoo.com/;_ylt=Ahu06i62s ... o8Wcj9tAcJ______________
-----------------------------------------------------------------List archives located at:
John
Don't drill out the prop. I had the exact same problem. If you have axcess
to a lathe you can make a
set of inserts out of 4130 and tap them for 3/8 bolts. You use to be able to
by them , they are quite expensive but I have not seen them adverstized
lately.
Charlie E.
also purchase them from some aircraft supply.
Sent: Sunday, January 13, 2008 10:11 AM
lately.
Charlie E.
John W 752 E
Any engine shop can supply you with a proper set of prop flange bushings
with 3/8 threads for your engine. Tap the 1/2" ones out and install the 3/8
ones. They do generally run about $40 a piece though.
Sent: Sunday, January 13, 2008 1:08 PM
Subject: Re: [rebel-builders] prop bolt question
John
lately.
Charlie E.
John W 752 E
Try Saber Mfg
I believe they are called drive lugs
Dale
Saber Manufacturing Inc.
3601 Nassau Ct, Granbury, TX 76049
Ph: (817) 326-6293 Fax: (817) 326-6330
E-mail: Sabermfg@alltel.net
Dale
John
lately.
Charlie E.
John W 752 E
