[rebel-builders] MT prop
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 4:17 pm
Hello Brian,
Did you know IVO Propellar (out of Chezc ?? republic), division of MT now,
is selling props for the Moose?
Thomas Thomas ordered one that he should have (but not on yet). I'll dig up
their email / contact info if youi want it.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Brian
Godden
Sent: Thursday, January 03, 2008 8:16 AM
Subject: [rebel-builders] MT prop
prop jugling here on a Moose....can any of you guys tell me which model of
the MT works best on a Moose (M14)...there are two different blade lengths.
Had some harmonic vibrations with some 3 blades.
Thanks Brian
Use fowl language with Chicktionary. Click here to start playing!
http://puzzles.sympatico.msn.ca/chickti ... id=htmlsig
Brian Godden
Post by Brian Godden » Sun Feb 19, 2012 4:17 pm
Hey Ted,
Actually here at Thomas's at the moment, and have been running the Chezc prop. He will tell you all about it.
Brian> From: tedwaltman@i1ci.com> To: rebel-builders@dcsol.com> Subject: RE: [rebel-builders] MT prop> Date: Thu, 3 Jan 2008 08:31:29 -0700> > Hello Brian,> > Did you know IVO Propellar (out of Chezc ?? republic), division of MT now,> is selling props for the Moose?> > Thomas Thomas ordered one that he should have (but not on yet). I'll dig up> their email / contact info if youi want it.> > Ted> > -----Original Message-----> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Brian> Godden> Sent: Thursday, January 03, 2008 8:16 AM> To: rebel-builders@dcsol.com> Subject: [rebel-builders] MT prop> > > prop jugling here on a Moose....can any of you guys tell me which model of> the MT works best on a Moose (M14)...there are two different blade lengths.> Had some harmonic vibrations with some 3 blades.> Thanks Brian> _________________________________________________________________> Use fowl language with Chicktionary. Click here to start playing!> http://puzzles.sympatico
..msn.ca/chicktionary/in
d
ex.html?icid=htmlsig> > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > > > > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > >
Post by Mike Kimball » Sun Feb 19, 2012 4:17 pm
IVO a division of MT? That's news to me. I can't find anything on the web
about that. IVO is based in California. Ivo Zdarsky, the founder, is from
Czechoslovakia but this all started with his escape from Communist
Czechoslovakia in an ultralight pushed along with a prop he made.
I have an IVO 84" 3-bladed, electric pitch control with constant speed
computer, Magnum airboat paddle prop on my V8 Super Rebel. I have good and
bad opinions of the prop. The good is that it is an extremely simply design
and assembly and is very light (28 pounds). It works well as advertised.
However, I have had trouble with the multiple plates that make up the
electric pitch control assembly. If you disassemble and reassemble, the
bolts bind on the plates and end up cutting threads into the aluminum
plates. Sometimes, the bolts are very difficult to remove and reinstall.
Aluminum gets inbedded into the bolt threads and that has to be cleaned out.
This also caused some minor damage to the threads in the prop hub that had
to be repaired with a tap. Smoothing out the holes in the plates has
certainly caused the holes to become enlarged. Unfortunately, the whole
thing has to be removed and reassembled multiple times to set up the pitch
stops properly.
Also, the electric brush assembly could be done much better. I have already
broken one of the flimsy plastic assemblies. And the electrical connectors
are some sort of weird size. I could not find a paddle connector that would
fit properly on the brush assembly. I ended up making my own connector,
soldered it in place, and covered the whole thing with household Goo to seal
it from the elements and to further ensure that it won't become
disconnected.
I have yet to observe this with the low time I have on the prop but a friend
of mine who ran the exact same prop on his airboat for a while reported that
the stainless steel leading edge tape eventually becomes detached.
Waltman
Sent: Thursday, January 03, 2008 6:31 AM
Hello Brian,
Godden
Thanks Brian
Brian Godden
The prop we are testing here is not an IVO....it is from Avia. It is a superb product, and very easy to work on.> From: mkimball@gci.net> To: rebel-builders@dcsol.com> Subject: RE: [rebel-builders] MT prop> Date: Thu, 3 Jan 2008 18:56:28 -0900> > IVO a division of MT? That's news to me. I can't find anything on the web> about that. IVO is based in California. Ivo Zdarsky, the founder, is from> Czechoslovakia but this all started with his escape from Communist> Czechoslovakia in an ultralight pushed along with a prop he made.> > I have an IVO 84" 3-bladed, electric pitch control with constant speed> computer, Magnum airboat paddle prop on my V8 Super Rebel. I have good and> bad opinions of the prop. The good is that it is an extremely simply design> and assembly and is very light (28 pounds). It works well as advertised.> However, I have had trouble with the multiple plates that make up the> electric pitch control assembly. If you disassemble and reassemble, the> bolts bind on the plate
r
eads into the aluminum> plates. Sometimes, the bolts are very difficult to remove and reinstall.> Aluminum gets inbedded into the bolt threads and that has to be cleaned out.> This also caused some minor damage to the threads in the prop hub that had> to be repaired with a tap. Smoothing out the holes in the plates has> certainly caused the holes to become enlarged. Unfortunately, the whole> thing has to be removed and reassembled multiple times to set up the pitch> stops properly.> > Also, the electric brush assembly could be done much better. I have already> broken one of the flimsy plastic assemblies. And the electrical connectors> are some sort of weird size. I could not find a paddle connector that would> fit properly on the brush assembly. I ended up making my own connector,> soldered it in place, and covered the whole thing with household Goo to seal> it from the elements and to further ensure that it won't become> disconnected.> > I have yet to observe this with the low time I
f
riend> of mine who ran the exact same prop on his airboat for a while reported that> the stainless steel leading edge tape eventually becomes detached.> > Mike> > -----Original Message-----> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Ted> Waltman> Sent: Thursday, January 03, 2008 6:31 AM> To: rebel-builders@dcsol.com> Subject: RE: [rebel-builders] MT prop> > Hello Brian,> > Did you know IVO Propellar (out of Chezc ?? republic), division of MT now,> is selling props for the Moose?> > Thomas Thomas ordered one that he should have (but not on yet). I'll dig up> their email / contact info if youi want it.> > Ted> > -----Original Message-----> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Brian> Godden> Sent: Thursday, January 03, 2008 8:16 AM> To: rebel-builders@dcsol.com> Subject: [rebel-builders] MT prop> > > prop jugling here on a Moose....can any of you guys tell me which model of> the MT works best on a Moose (M14)...there are two dif
H
ad some harmonic vibrations with some 3 blades.> Thanks Brian> _________________________________________________________________> Use fowl language with Chicktionary. Click here to start playing!> http://puzzles.sympatico.msn.ca/chickti ... id=htmlsig> > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > > > > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > > > > > > ---------------------------------------------------------------
e
Post by Bob Patterson » Sun Feb 19, 2012 4:17 pm
Hi Brian !
If that's the Avia I remember, it had a really slick way of giving
constant speed - without an engine-driven governor ! They had
a pump inside a free-turning spinner outer shell, with vanes on it.
The faster you flew, the faster the spinner turned, and that increased
pumping, and the pitch for faster cruise ! Brilliant, simple, and
light ....
Thought the company had a bright future - until they were
bought out .... glad to hear it's in production at last !
bobp@prosumers.ca
http://www.prosumers.ca
you disassemble and reassemble, the> bolts bind on the plates and end up
cutting th
r
with the lo w time I have on the prop but a
f
MT works best on a Moose (M14)...there ar e two different blade lengths.>
H
Brian Godden
Hey Bob,
This beauty uses the Russian governor, or their own, and has been tested on the Yak 18 (which I understand they made it for as the Russians are remanufacturing a bunch).
Huge paddle blades, and to remove the blades one clamp bolt and they unscrew!!!
Brian> From: bobp@prosumers.ca> To: rebel-builders@dcsol.com> Subject: Re: [rebel-builders] MT prop> Date: Fri, 4 Jan 2008 15:28:36 +0000> > > Hi Brian !> > If that's the Avia I remember, it had a really slick way of giving> constant speed - without an engine-driven governor ! They had> a pump inside a free-turning spinner outer shell, with vanes on it.> The faster you flew, the faster the spinner turned, and that increased> pumping, and the pitch for faster cruise ! Brilliant, simple, and> light ....> > Thought the company had a bright future - until they were> bought out .... glad to hear it's in production at last !> > -- > ......bobp> bobp@prosumers.ca> http://www.prosumers.ca> http://bpatterson.qhealthbeauty.com> http://apatterson2.qhealthzone.com> http://apatterson2.ordermygift.com> > -------------------------------orig.------------------------- > On Friday 04 January 2008 15:13, Brian Godden wrote:> > The prop we are testing here is not an IVO....it is from Avia. It is a> > supe
s
y to work on.> From: mkimball@gci.net> To:> > rebel-builders@dcsol.com> Subject: RE: [rebel-builders] MT prop> Date:> > Thu, 3 Jan 2008 18:56:28 -0900> > IVO a division of MT? That's news to me.> > I can't find anything on the web> about that. IVO is based in California.> > Ivo Zdarsky, the founder, is from> Czechoslovakia but this all started> > with his escape from Communist> Czechoslovakia in an ultralight pushed> > along with a prop he made.> > I have an IVO 84" 3-bladed, electric pitch> > control with constant speed> computer, Magnum airboat paddle prop on my V8> > Super Rebel. I have good and> bad opinions of the prop. The good is that> > it is an extremely simply design> and assembly and is very light (28> > pounds). It works well as advertised.> However, I have had trouble with> > the multiple plates that make up the> electric pitch control assembly. If> > you disassemble and reassemble, the> bolts bind on the plates and end up> > cutting th> > r> > eads into the aluminum> plat
s
are very difficult to> > remove and reinstall.> Aluminum gets inbedded into the bolt threads and> > that has to be cleaned out.> This also caused some minor damage to the> > threads in the prop hub that had> to be repaired with a tap. Smoothing out> > the holes in the plates has> certainly caused the holes to become> > enlarged. Unfortunately, the whole> thing has to be removed and> > reassembled multiple times to set up the pitch> stops properly.> > Also,> > the electric brush assembly could be done much better. I have already>> > broken one of the flimsy plastic assemblies. And the electrical> > connectors> are some sort of weird size. I could not find a paddle> > connector that would> fit properly on the brush assembly. I ended up> > making my own connector,> soldered it in place, and covered the whole> > thing with household Goo to seal> it from the elements and to further> > ensure that it won't become> disconnected.> > I have yet to observe this> > with the lo w time I have on t
he prop but a> > f> > r
i
end> of mine who ran the exact same prop on his airboat for a while> > reported that> the stainless steel leading edge tape eventually becomes> > detached.> > Mike> > -----Original Message-----> From:> > mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Ted>> > Waltman> Sent: Thursday, January 03, 2008 6:31 AM> To:> > rebel-builders@dcsol.com> Subject: RE: [rebel-builders] MT prop> > Hello> > Brian,> > Did you know IVO Propellar (out of Chezc ?? republic), division> > of MT now,> is selling props for the Moose?> > Thomas Thomas ordered one> > that he should have (but not on yet). I'll dig up> their email / contact> > info if youi want it.> > Ted> > -----Original Message-----> From:> > mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Brian>> > Godden> Sent: Thursday, January 03, 2008 8:16 AM> To:> > rebel-builders@dcsol.com> Subject: [rebel-builders] MT prop> > > prop> > jugling here on a Moose....can any of you guys tell me which model of> the> > MT works b
t
here ar e two different blade lengths.>> > H> > ad some harmonic vibrations with some 3 blades.> Thanks Brian>> > > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > >
Introducing the City @ Live! Take a tour!
http://getyourliveid.ca/?icid=LIVEIDENCA006
