[rebel-builders] Transfrerring holes
Dale Fultz
Post by Dale Fultz » Sun Feb 19, 2012 4:11 pm
You can always go down to the local sheet metal shop and get them to shear
you two pieces of stainless about 3/4 of inch wide, long enough to reach in
from the end put a bold down thru the two ends to hold them together and
drill a #30 hole in the other end high tack a rivet to the bottom piece the
rivet sticking in to line up with each hole and use the top hole to line up
where the hole is supposed to be in the skin that way you won't need to
transfer all the holes from the old skin.... Just and idea for an extended
hole finder, I can make you one if you give me a length of how long it
would need to be...Dale
