moose cargo pod
Brian Godden
moose cargo pod
Post by Brian Godden » Sun Feb 19, 2012 4:10 pm
I guess most of you Moose drivers have now seen Thomas's cargo pod, pictured on www.goflyamoose.com hanging under his beautiful Moose.
He is going to make these available if you want one. I flew the aircraft a couple of weeks ago, and actually forgot it was there.
Flight testing is almost complete, the pod weighs about 32lbs (fiberglass and carbon fiber) so if you are interested e-mail me direct at brian_godden@hotmail.com.
It only fits a land plane at present, as the rear mount is actually the rear float mount.
You will also see the latest Turbo Moose pictured on the site....a while back somebody asked about increasing fuel capacity....well the tip tanks I figured out we installed on that aircraft. Guess they work!?
Brian
Use fowl language with Chicktionary. Click here to start playing!
http://puzzles.sympatico.msn.ca/chickti ... id=htmlsig
