I am using the B&C angled oil adapter on the Murphy dynafocal mount and a
Superior XP O-360. The 1.4" spacer was required to clear the extra angled
arm mentioned by Walter below.
Oil filter nicely clears the mount, firewall and cowling.
645 Elite
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com] On Behalf Of Walter
Klatt
Sent: Monday, November 26, 2007 7:41 PM
To:
rebel-builders@dcsol.com
Subject: RE: [rebel-builders] Angled oil filter adapter
Yes, I looked at some that used the B&C adapter, but not sure if they are
different than my ECI one. I think Drew has the identical one to mine. And I
can see that the conical mount would be no problem. The dynafocal mount has
that extra angled arm on the left side that comes between the filter and the
engine.
Sent: November 26, 2007 7:12 PM
To:
Subject: Re: [rebel-builders] Angled oil filter adapter
Several O-360/Elite installations popped up in the search... they used a
1.4" spacer.
oifa@irishfield.on.ca>
To: <
rebel-builders@dcsol.com>
Sent: Monday, November 26, 2007 6:01 PM
If I remember right...weren't people using the 1.5" spacer?
Walter.Klatt@shaw.ca>
To: "Rebel-Builders" <
Sent: Monday, November 26, 2007 9:58 PM
Subject: [rebel-builders] Angled oil filter adapter
I have the new angled oil filter adapter on my new 360 engine. I am not
sure
if it will fit with the dynafocal mount though. What have others used?
Did
you have to get an extension for your adapter to move it out a bit to fit
around the mount?
Drew, I vaguely recall that you had one of these with your new engine?
Did
it fit OK?
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
