list of items for Moose
Scott Berry
Post by Scott Berry » Sun Feb 19, 2012 4:05 pm
Hello there everyone,
I am formulating a list of items for the Moose. I would like to have input
to which items I should either change and what model possibly to change to
or what items I need to add. This is a first draft so pardon any mis
spellings here. I am pasting this in to the email message because I am
uncertain if attachments are allowed on the list.
. Other company names would also be helpful please if items can be bought
from other companies. Thanks so much for looking at this and I apologize
that the list is so long. I am going for a 28 volt electrical system here
also that might help you formulate opinions as well.
List Begins Here
Aircraft Equipment
Efis System
FlightDEK-D180 System (Bright Screen)
100565-001
Price: $3,400.00 USD 3,400.00 USD Includes EDC, mounting tray, USB to
Serial converter
Internal Battery
100096-000
Price: $130.00 USD 130.00 USD
Wiring Harness
100425-000
Price: $90.00 USD 90.00 USD
AOA Pitot Probe - 12V Heated
100667-000
Price: $450.00 USD
Transponder serial to parallel converter
100362-000
Price: $80.00
Fuel Flow Sensor
100403-001
Price: 200.00 USD
HS34 Horizontal Mount
100790-001
Price: $650.00 USD
Price Total: $5,000.00 USD
From Manufacturer's Web Site: www.dynonavionics.com
ANR Headset for Moose
Price: $375.00 per pair
ANR for Helicopters
Price: $400.00 per pair
Hand Microphone
Telex 100TRA Dynamic Microphone </catalog/avpages/100tra.php>
Price: $107.95
Intercom
INTERCOM GEAR WARN DEVICE II
Price: $210.95
Push to Talk Switch
TELEX PT-300 PUSH-TO-TALK
Price: $51.50
Fuses
GLASS FUSE AGC-35 35AMP
Price: $0.48
Total 6: $2.88
Battery
GILL BATTERY G-35 W/ACID
Price: $154.95
Battery Terminal Tool
BATTERY TERMINAL TOOL
BOGERT BATTERY TERMINAL TOOL
Price: $8.80
Ignition Switches
BENDIX IGNITION SWITCHES
With push to start feature. Includes two keys. Furnished with Switch Plate
10-357210-1
Price: $259.50
Filters
Magneto Filter
Price: $53.50
Ameri-King Noise Filters
Price: $79.85
Ameri-King AK-950-FTR1
Price: $72.25
Pin and Socket Tools (Finished Buying)
AMP INS/EXTR.TOOL 22-28AWG G/W
Price: $8.60
AMP INS/EXTR. TOOL 16 AWG B/WH
Price: $13.50
Interior Lighting
UV150 12 VOLT DUAL LAMP SYSTEM Price:
$170.00
Battery Charger
BATTERY CHARGER CR612 +
Price: $63.95
Compass Instrument
Vertical Card Compass PAI-700 14V +
10-00421
Price: $269.95
PRECISION AIRCRAFT SCALES
14,500 LB AIRCRAFT SCALE
Price: $6302.00
Video
Super Deluxe Kit - Includes camera mount system, built in grip switch, and
LCD screen
11-04320
Price$785.00
Trafic Alerting System
ASPEN AT300 TERRAIN TSOD
11-02908
Price: $2795.00
Gps
KLN-35A GPS AMERICA W/ HARNESS
11-02719
$2112.95
Flap Positioning System
FPS-PLUS WITH ELEV TRIM
11-02980
Price: $269.00
Autopilot
TRUTRAK DIGITRAK 2-1/4"
11-01595
$1650.00
Base Radio Station
ICOM ANTENNA FOR THE IC-A200B
11-18581
Price: $198.00
PS-80 W/ IC-A200 + FREE MIKE
11-00801
Price: $1385.00
Resin
VINYL ESTER 411-350PA 1G KIT
01-07355
Price: $47.50
Hand Protection
01-00598
HEAVY DUTY LATEX GLOVES (50)
Price: $14.95
Finishing Systems
09-01609
FINISHLINE SEALER GLOSS
Price: $9.40
Mixing Supplies
Mixing Containers
01-00915
1 QT PLASTIC MEASURING CONTAIN
Price: $0.88
01-00926
LID FOR QT MEASURING CONTAINER
Price: $0.51
01-00330
2-1/2 QUART CUP
Price: $1.46
01-00331
2-1/2 QT LID FOR PN 01-00330
Price: $0.60
Mixing Sticks
01-25800
MIXING STICKS BOX OF 500
Price; $9.85
Scale
12-01580
PELOUZE SCALE PE5
Price: $88.75
Glove Liners
01-36600
COTTON GLOVE LINERS
Price: $0.65
Power Tools
01-00130
DREMEL 3956 MULTI PRO TOOL KIT
Price: $137.95
Knife Kit
01-17400
X-ACTO KNIFE SET #5083
Price: $32.40
Dischargers
STATIC DISCHARGER 16630
11-16630
Price: $51.65
Stall Warning System
AEROMAX SW2.2 STALL WARN SYS
10-00297
Price: $435.95
AEROMAX AUTO GROUND SHUTOFF
10-00298
Price: $71.00
Power Panels
11-00430
EXP BUS EXP-TRAY
Price: $424.00
11-00433
EXP BUS BRKT2
Price: $21.95
11-00431
EXP BUS EXP2V
Price: $299.00
11-00432
EXP BUS IND2
Price: $129.95
Hardware Kits
04-00400
HOMEBUILDERS HARDWARE KIT
Price: $46.30
04-00500
HOMEBUILDERS HARDWARE KIT W/ CABINET
Price: $84.92
Radio/Nav Equipment
Narco package No. 2D+ Includes MK 12D-Plus NAV/COM transceiver with
glideslope and ID 825 VOR/LOC/GS indicator with glideslope. Specify 28V
(28 Volt) P/N 11-12622
Price: $4075.00
Oil Drain Systems
13-04950
DRIP TRAP 20" X 20"
$22.95
Total: $137.70
Fuel Pump
476411
476411E FACET PUMP
Price: $176.95
Oil Sump Pump
FACET ELECTRIC FUEL PUMPS
40105
40105 FACET SOL ST FUEL PUMP
Price: $33.30
Alcohol
DENATURED ALCOHOL
P/N DENACO2
Price: $12.90
Cutters and Shears
Razor Blades
01-24904
SINGLE-EDGE RAZOR BLADES
Price: $0.13
Total: $1.56
Needle Files
12-00081
PERMA-GRIT NEEDLE SET W/HNDLS
Price: $45.90
Fillers
Dynalite
01-00368
DYNALITE FILLER 494 GALLON
Price: $29.60
Total: $59.20
Paint
Zolatone Paint
Marble Stone
20-63
Price: $99.75
Air Gun Clean
FLIGHT GLOSS GUN GLEANER QUART
Price: $12.00
Total: $24.00
Rollers
Roller Tray
09-00146
FLIGHT GLOSS 4" ROLLER TRAY
Price: $3.95
09-00144
FLIGHT GLOSS 6" ROLLER
Price: $9.25
09-00145
FLIGHT GLOSS 6" FOAM REFILL
Price: $5.30
Ratio Pumps
West System Pump Pack
01-00318
WEST SYSTEM 301/303 PUMP PACK
Price: $11.50
Primer
DUPONT FILL 'N SAND
SURFACE PRIMER GAL. 210S
01-00379
Price:$177.95
Total: $533.85
Degreasers
Dilution Ratios:
Heavy carbon: 1 part X-ITT Carbon Remover & Cleaner to 1 part water.
Heavy soil/degreasing: 1 part X-ITT Carbon Remover & Cleaner to 2-10 parts
water.
Cleaning instructions: Apply by spray, foam or hand. Allow suf? cient dwell
time (two to ten minutes). Agitation (light scrubbing) will enhance cleaning
ability and accelerate the results. Completely rinses with water.
Waste Treatment:
There are no federal regulations restricting the disposal of X-ITT Carbon
Remover & Cleaner concentrate into municipal wastewater systems. However,
local
regulations imposed by a state or municipality may regulate speci?c
discharges, BOD and/or COD limits.
09-00769
X-IT CARB CLEANER AND REMVR GL
Price: $22.80
Total: $45.60
De-Icers
BF GOODRICH ICEX II DE-ICERS
09-42530
Price: $184.95
BF GOODRICH DE-ICE SRAY 16 OZ
09-42531
Price: $119.85
BF GOOD DE-ICER CEMENT 8 OZ
09-42535
Price: $57.25
Fire Barier
The Fire Stops Here
Fire Barrier Latex Primer - Quart
05-02615
Price: $25.90
Total: $77.70
Fuel Tank Sealant
Pro-Seal Fuel Tank Sealant (Quart)
09-38565
Price: $86.50
Grips, Pistol/ Stick
RAC STICK GRIP G7 W/PUSH BTN
11-09925
Price: $169.95
Total: $339.90
Door Sealers
DOOR STEWARD LH & RH KIT
05-00922
Price: $297.00
Total: $594.00
Air Squeeze Kit
Squeeze-Out:
Top & Rear of the Door
Air-Seal:
Bottom and Forward Door Where the Hinges are Located.
ear-Popping Tight, Flex, Ez Conform Will Not Push Door-Out.
05-02217
Price: $125.95
AvTek Thin Seal (Door) -03
05-02201
Price:$79.95
Electrical Wire
Wire for Dynon D100
11-14522
WIRE UNSHD 22759/16 22GA WHITE
Price: $0.19
Total Price: $190.00
Circuit Breakers
11-03928
W23X1A1G3 CIRCUIT BREAKER for Dynon Avionics D100
Price: $29.90
Total: $89.70
Elt's
Ameri-King ELT AK-450
11-02790
Price: $189.95
Transponder
11-02436
KING CRWN KT76A 14V W/HARNESS
Price: $1719.06
11-00913
KING KT76A 28V CONVERTER KIT
Price: $103.95
11-17995
TED TRANSPONDER ANTENNA
Price: $18.95
Relays
MID-CONT. REMOTE RELAY UNT 28V
10-02127
Price: $698.00
Intercoms
Aircraft Spruce Skycom 2 & 4 Place Portable Intercoms
11-11860
SKYCOM 200 2 PLACE INTERCOM
Price: $96.50
List ends here
Scott
