guide from the inside of the fuselage but reversed it so that the cable
guide part (is that what you refer to as the fairlead??) is facing out
through the slot so that the cable is kept in place as it goes through the
skin. I think I also used a laser pointer on a level to roughly get my
initial hole.
Jim 333
On 11/7/2007 11:50 PM, "Mike Kimball" <mkimball@gci.net> wrote:
I found my starting point by passing a long drill bit through the cable
fairleads in the bulkhead and noted where the bit hit the fuselage skin. I
don't know if this area is accessable to do that with the quick build
fuselage you have. I also discovered that the slots for the cables turn out
to not be parallel to the fuselage. When moving the rudder stop to stop I
quickly found out that the cables move up and down a bit causing the final
slot to be at an angle. I also installed a fairlead right at the forward
side of the slot to prevent the cable from rubbing there otherwise my slot
would have to be much longer.
Waltman
Sent: Tuesday, November 06, 2007 10:30 AM
Subject: [rebel-builders] Moose: holes for rudder cables in rear fuselage?
I'm having trouble finding any guide in the manual for where in each side of
FUS-357 one should cut the holes for where the rudder cables exit the
fuselage. I have pictures from a couple of other Moose that I can use as a
rough reference-is there any specific measurement in the manual that I
missed?
Thank you,
