[rebel-builders] Moose: holes for rudder cables in rear fuse
[rebel-builders] Moose: holes for rudder cables in rear fuselage?
Post by Mike Kimball » Sun Feb 19, 2012 4:05 pm
I found my starting point by passing a long drill bit through the cable
fairleads in the bulkhead and noted where the bit hit the fuselage skin. I
don't know if this area is accessable to do that with the quick build
fuselage you have. I also discovered that the slots for the cables turn out
to not be parallel to the fuselage. When moving the rudder stop to stop I
quickly found out that the cables move up and down a bit causing the final
slot to be at an angle. I also installed a fairlead right at the forward
side of the slot to prevent the cable from rubbing there otherwise my slot
would have to be much longer.
Waltman
Sent: Tuesday, November 06, 2007 10:30 AM
Subject: [rebel-builders] Moose: holes for rudder cables in rear fuselage?
I'm having trouble finding any guide in the manual for where in each side of
FUS-357 one should cut the holes for where the rudder cables exit the
fuselage. I have pictures from a couple of other Moose that I can use as a
rough reference-is there any specific measurement in the manual that I
missed?
Thank you,
