Yes, I am still using one mag, so at worst, my engine won't quit. My panel
is my "own" design, and I know at the very least, I would need a heavier alt
wire and some fuses. And I can't remember what the wires were around my
amp/volt meter. I am really trying to avoid taking my panel apart with the
new engine. But if I did it again, for sure, I would make changes.
Lots of discussions and opinions on the net about this, but for now, I think
I am inclined to just take my chances with the internally regulated
alternator.
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com] On Behalf Of Ken
Sent: Sunday, October 28, 2007 6:46 PM
To:
rebel-builders@dcsol.com
Subject: Re: [rebel-builders] Internally regulated alternators
The solid state spike protectors (transorbs etc.) do exactly that. They
will tame a momentary spike if you believe there really is such a thing.
They are useless for a real overvoltage though as they will fry in a
fraction of a second with that kind of energy going into them. Yes a
large battery will slow the voltage rise but stuff is still going to fry
in a few seconds or so. Some guys feel they can manually shut off their
alternator in a few seconds if they have a high voltage warning. I'm
very skeptical as it will likely take longer to identify what is
happening but in any case there is no way to shutdown a runaway internal
regulating alternator unless you have a contactor to disconnect it or a
big panel mounted CB (which is generally a bad idea).
Most electrical systems would need little if any upgrading to handle a
60 amp alternator. At most - a heavier wire to the starter or battery
and a larger alternator CB or fuse. Good design often means you already
have the heavier wire and CB as there are good reasons to oversize those
two components..
One of the reasons that I used a small 40 amp alternator was for the
smaller current in the event of a runaway alternator.
The OV risk is low but real and there have been some heated discussions.
I've had one real OV on my secondary John Deere alternator and I'm glad
I had the protection. It was on the ground and a direct result of
starting the engine with one of my two wee batteries stone dead. The
battery wouldn't accept current and the regulator couldn't handle the
situation.
Do you have one magneto or self sustaining P-mag (or is it E-mag?)? If
not and you are not worried about avionics, there is another way to
accomplish the protection if you are going to add a second battery
anyway. $20. of parts would simply automatically isolate the second
battery from the alternator.
Walter Klatt wrote:
Thanks, Ken. That Plane Power unit is one of the ones that I was looking
at,
but my panel wires/fuses, etc were not designed for 60 amps, so I went with
the 40 amp Lamar unit.
I was searching on the internet, and thought I saw some kind of cheap
(about
1 dollar) device that could be used to protect a circuit. I think it was
called Transport or something like that and saw it in the aeroelectrics
list. I looked again, but couldn't find it. I also remember seeing some
discussion by someone else saying that it really wasn't necessary, and your
normal internal regulator should be enough.
The LSE instructions say to wire the power supply directly to the + battery
terminal. I think the intent is to buffer the voltage with the battery, as
well as have less radio noise.
Sent: Sunday, October 28, 2007 5:21 PM
To:
The ONLY internally regulated unit that I would consider to have
acceptable overvoltage protection is from Plane Power. They add
additional simple crowbar circuitry. Most modern regulator ic's claim OV
protection but once the ic has failed to regulate you can bet the same
ic is not going to reliably protect anything. That has been learned the
hard way.
http://www.plane-power.com/images/inter ... mental%20a
l
ternator%20information.pdf
I use a separate crowbar module to trip a contactor and disconnect the
alternator. Bob Knuckolls of the aeroelectric connection has an
improved version of that system in the works that should be every bit
as good as what plane power sells. Frankly if you have at least one
magneto or similar, I think it is quite reasonable to use any internally
regulated alternator. I was not prepared to risk it with my EFI engine
though. Some guys with expensive avionics have also wished they'd
installed OV protection...
Walter Klatt wrote:
With my new engine, I am getting a 40 amp internally regulated Lamar
alternator. Can anyone tell me if this internal regulator also provides
for
over voltage protection? My new LSE EI system requires over voltage
protection.
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
