than 7/8" between holes (actually .884").
Best Regards,
Scott Hibbs
hibbs@pacifier.com
Doug, The method I used to drill the tube holes was to wrap a 1" wide
piece
of paper around the tube, mark the overlap, remove and lay flat. This is
now
the circumference of the tube. Run a line down the center which is now
1/2" required from the end, mark the line into even (8) distances and
retape
onto the tube and "drill away". I actually made many of these
templates for
all tube ends.-Bob J "REBEL 652"
theFrom: "Snader, Douglas E." <snaderde@tvfr.com>
To: "'murphy-rebel@dscol.com'" <murphy-rebel@dscol.com>
Subject: drilling holes in a tube
I have one more question what is the best way to measure and mark
torque tubes for drilling the eight evenly spaced holes?
