relatively unstressed area. Do debur carefully however. The hole is out
of any windflow which would blow trash inside and there are other openings
around the plane that are not secured. I did consider a plastic hole plug
(see your home supply or hadware store) if I do decide to plug against mice
or the mud dauber wasps we are blessed with here in the South.
Elite serial 611E
*---------------------------------------------------------------------------From: list-server <list-server@dcsol.com>
To: rbaker@sumter.net
Subject: murphy-rebel Digest for 10 Jun 2000
Date: Sunday, June 11, 2000 12:01 AM
*---------------------------------------------------------------------------The Murphy Rebel Builders List is for the discussion
--------------------------------------------------------------------------murphy-rebel Digest for 10 Jun 2000
Topics covered in this issue include:
1: Horizontal Stabilizers-Rebel
by "Roger & Alice Hoffman" <rognal@continet.com>
2: RE: Horizontal Stabilizers-Rebel
by Bob Patterson <bob.patterson@canrem.com>
11 Message:0001
--------------------------------------------------------------------------From: "Roger & Alice Hoffman" <rognal@continet.com>
Subject: Horizontal Stabilizers-Rebel
Mr. Baker,
You wrote: "My solution, confirmed by Murphy,
was a 5/8" hole located at the "V" in the stabilizer. A short 3/8"
socketwith universal can access all 4 of the hinge bolts for torque
checking. "
What covers the hole? and did you put a doubler behind it or no?
Thanks for your help.
Roger #687R
Eugene, OR USA
22 Message:0002
-----------------------------orig.----------------------------------------To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Subject: RE: Horizontal Stabilizers-Rebel
Brian,
Maybe you'll get a chance to exercise your trim servo if you can
come on the Ramble !! ;-)
We certainly will have a LOT of camping gear & 'stuff' for this
one !! But, you're right - even with that load, it only takes a couple
of taps on the trim button, and then we leave it alone ... Isn't this
GREAT ??!! (not at all like a CessPool) :-)
....bobp
longAt 04:24 PM 6/9/00 -0400, you wrote:Hi Bob
Nobody has had a problem yet with the trim tab servo because it goes so
flightwithout use. I know I am just kidding you, but seriously, in most
been ofsituations with just varying fuel loads and passengers, the trim has
lotlittle value. As Wayne points out, with a great deal of baggage i.e. a
yet.of weight aft, it may come more into play. I have not experienced this
---------------------------------orig.--------------------------------------Regards
Brian #328R
Sent: Thursday, June 08, 2000 12:52 PM
Subject: Re: Horizontal Stabilizers-Rebel
Roger,
Most builders here have decided to add inspection covers later,
IF and WHEN they are needed. The trim tab servo is usually mounted on
a separate plate, so it can be removed easily, if needed. (nobody has
had a problem yet ...)
anyoneAt 06:57 PM 6/7/00 -0700, you wrote:I'm about to finish the horizontal stabilizers and was wondering if
skinrecommends (or not) putting an access/inspection plate in the bottom
-tostabilizeraccess/inspect the bolts/nuts of the (inner) elevator hinge, rearattach bracket, and the strut attach bracket?
Roger #687R
Eugene, OR USA
----------*The Murphy Rebel Builders List is for the discussion
http://www.dcsol.com/murphy-rebel/lists/default.htm*-------------------------------------------------------------------------
---------**--------------------------------------------------------------------------The Murphy Rebel Builders List is for the discussion
