tail ski
LisaFly99
tail ski
Post by LisaFly99 » Fri Feb 17, 2012 5:56 pm
In a message dated 6/3/00 9:56:55 PM Central Daylight Time,
oifa@irishfield.on.ca writes:
<< The other great benefit
of not running a tail ski is, that when you start to run out of runway you
can haul back on the stick forcing the tail wheel into the snow to use as a
brake. Yes you might break the tail spring (if you use those fiberglass
ones), but it is better than taking your wings off in the trees!!!!! >>
WAYNE
Is that the voice of experience? About tail wheel springs was it you that
said they where using a modified trailer spring from Prince auto, If so I
would like to bother you for some info on the installation and part # of
spring. Also I'm about to order a full swiveling tail wheel any one out there
have any suggestions.
Phil&Lisa Smith #460 N414D
LisaFly99
Tail Ski
WAYNE
Is that the voice of experience? Speaking of tail wheels are you the one
running a modified trailer spring from Prince auto? If so could I get some
installation info from you and maybe a part # for the spring. Also I'm about
to order a full swiveling tail wheel any one out there have any suggestions
Phil&Lisa Smith #460 N414D.
Tail Ski
Post by Bob Patterson » Fri Feb 17, 2012 5:56 pm
Phil,
If you don't want to use the Murphy full swivel tail wheel,
then go for a Scott 3200 (they make a 2200, but it's almost the same
price, ! ). Generally, the extra weight of the 3200 helps the CG ;-)
Avoid the Maule tailwheels - they're cheaper (in 2 ways ! :-( )
They all tend to shimmy as they get older, and that's hard on the tail.
Angus had problems with a bad (porous) casting on a 1 year old Maule
tailwheel - it shattered at the rivet for the serial number plate. His
rudder & elevator & trim tab were damaged in the ensuing flailing !!
Haven't broken a fibreglass tailspring yet, but suspect that
would be better than a bent fuselage ! (just MHO :-) )
-------------------------------orig.-------------------------------------
WAYNE
