Don't know how you could build one of these planes without 90* tight fit,
and what has been nearly as valuable to me is a "pancake". Really, really
helpful. You have to have some threaded drill bits for these things, but it
is so worth it. I got my stuff on ebay at very reasonable prices.
Jesse
_________________________________________________________________From: Ken <klehman@albedo.net>
Subject: Re: [rebel-builders] Doublers
Date: Tue, 26 Jun 2007 22:12:29 -0400
FWIW we have had some discussion about wrinkles at the bottom of the
wheel well sides just aft of the bulkhead that the gear mounts on. I
decided to increase the strength of the diagonal stringers and to tie
them into the vertical angles (FL202 ??) with a doubler there. A
doubler bonded with proseal might help but I'd sure prefer rivets into
the stringer and the vertical angles.
Drew - Princess Auto has a pneumatic angle drill advertised for $29.
this week. That's even cheaper than that angle attachment thingme for
dremels. Neither will get in as tight as the specialty aviation angle
attachments.
Walter Klatt wrote:
are,Drew, I would be interested further to know exactly where these cracksDrewand what you think may have caused them. Any pics to post?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf OfapartDalgleish
Sent: Tuesday, June 26, 2007 3:51 PM
Subject: [rebel-builders] Doublers
Hi guys I found a couple small wrinkles and cracks in my float wheelwell.
No leaks last year but I want to deal with this while I have the gearbondto install die springs. My question is are rivets really neccessary toaa doubler to the inside of the wheel well side skin. I would need to getfairlyright angle drill if I wanted to get holes in there but it would beeasy to clamp it in place with some wedges. I think I'll use pro-seal for
the bonding agent instead of sikaflex. Any comments?
Like puzzles? Play free games & earn great prizes. Play Clink now.
http://club.live.com/clink.aspx?icid=cl ... ltextlink2
