[rebel-builders] RE: Doublers
Post by Mike Kimball » Sun Feb 19, 2012 12:12 pm
I can't imagine how I would have finished my Super Rebel without my tight
fit drill kit. You would not believe the places I've been able to drill a
hole, sometimes using a right angle drill in combination with the tight fit
attachment.
http://www.aircraftspruce.com/catalog/t ... oolkit.php
044SR
bransom@dcsol.com
Sent: Tuesday, June 26, 2007 5:38 PM
Subject: [rebel-builders] RE: Doublers
For a right angle drill you can get a angle die grinder with 1/8" collet,
cheap (10-23 usd), from harborfreight.com. I used this to drill from
inside out on my tailcone/Fus-30.
http://mae.ucdavis.edu/ransom/Murphy/2007/0701/
-Ben
On 6/26/2007 1:51 PM, drewjan@cabletv.on.ca wrote to rebel-builders:
Hi guys I found a couple small wrinkles and cracks in my float wheelwell.
No leaks last year but I want to deal with this while I have the gear
apart
to install die springs. My question is are rivets really neccessary to
bond
a doubler to the inside of the wheel well side skin. I would need to get a
right angle drill if I wanted to get holes in there but it would be
fairly
easy to clamp it in place with some wedges. I think I'll use pro-seal for
the bonding agent instead of sikaflex. Any comments?
