[rebel-builders] Doublers
Post by Walter Klatt » Sun Feb 19, 2012 12:12 pm
Drew, I would be interested further to know exactly where these cracks are,
and what you think may have caused them. Any pics to post?
Dalgleish
Sent: Tuesday, June 26, 2007 3:51 PM
Subject: [rebel-builders] Doublers
Hi guys I found a couple small wrinkles and cracks in my float wheelwell.
No leaks last year but I want to deal with this while I have the gear apart
to install die springs. My question is are rivets really neccessary to bond
a doubler to the inside of the wheel well side skin. I would need to get a
right angle drill if I wanted to get holes in there but it would be fairly
easy to clamp it in place with some wedges. I think I'll use pro-seal for
the bonding agent instead of sikaflex. Any comments?
Post by Ken » Sun Feb 19, 2012 12:12 pm
FWIW we have had some discussion about wrinkles at the bottom of the
wheel well sides just aft of the bulkhead that the gear mounts on. I
decided to increase the strength of the diagonal stringers and to tie
them into the vertical angles (FL202 ??) with a doubler there. A
doubler bonded with proseal might help but I'd sure prefer rivets into
the stringer and the vertical angles.
Drew - Princess Auto has a pneumatic angle drill advertised for $29.
this week. That's even cheaper than that angle attachment thingme for
dremels. Neither will get in as tight as the specialty aviation angle
attachments.
Dalgleish
Post by Drew Dalgleish » Sun Feb 19, 2012 12:12 pm
Thanks for the responses guys. I guess the concensus is that it needs
riveted. I don't have a compressor at the hangar so I'll get a right angle
attachment for an electric drill. The cracks are on the left float only on
both sides of the wheelwell side skins right at the bottom front corner and
just behind the attach angle. As for what caused them I can only guess that
it taxiing on rough surfaces or a bad landing I don't remember any real
stinkers but thet're the ones you want to forget. I'll try to get some
pictures this week.
Dalgleish
Bob Fisher
Post by Bob Fisher » Sun Feb 19, 2012 12:12 pm
Sent: Wednesday, June 27, 2007 9:23 AM
Subject: RE: [rebel-builders] Doublers
that
pictures this week.
are,
Dalgleish
apart
bond
fairly
Bob Fisher
hi drew let me give you my opinion as to why landing and taxying with
those suspenionless pucks!!!
all that force has to be a
that
pictures this week.
are,
Dalgleish
apart
bond
fairly
I hope you're right Bob. My pucks are history I found the cracks while I
was installing the die spring suspension.
that
pictures this week.
are,
Dalgleish
apart
bond
fairly
Which pucks did you have, Drew, original thin ones that squish out, or the
newer stiff thick ones?
I still have my blue Elite nosewheel ones on mine, and they are still firm
as new.
Dalgleish
Sent: Wednesday, June 27, 2007 7:01 AM
Subject: Re: [rebel-builders] Doublers
angle
on
that
pictures this week.
are,
Dalgleish
apart
bond
fairly
Mine were the origional ones that came withthe kit. Yellow and yes they
squished out they also seemed to set in the squished state. On Bob Fishers
floats you can bounce up and down on them and see lots of movement on mine
there was nothing.
as new.
Dalgleish
angle
on
that
pictures this week.
Just uploaded a pic of one of the cracks. The one on the other side is
about the same but out of 10 tries only one picture was any good. Also put
up a pic of the die spring gear installed.
Dalgleish
ray.mason
Post by ray.mason » Sun Feb 19, 2012 12:12 pm
The spring gear looks good. Did you do the same as Ken and Bob?. The
cracks are in the same place as mine. I don't have the crease that you have
though. Are you going to fix them now or wait untill the flying season is over?
Ray
-> Just uploaded a pic of one of the cracks. The one on the other side is
-> about the same but out of 10 tries only one picture was any good. Also
put
-> up a pic of the die spring gear installed.
-> At 04:36 PM 6/26/2007 -0700, you wrote:
-> >Drew, I would be interested further to know exactly where these cracks
are,
-> >and what you think may have caused them. Any pics to post?
-> >Walter
-> >-----Original Message-----
-> >From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf
Of Drew
-> >Dalgleish
-> >Sent: Tuesday, June 26, 2007 3:51 PM
-> >To: rebel-builders@dcsol.com
-> >Subject: [rebel-builders] Doublers
-> >Hi guys I found a couple small wrinkles and cracks in my float
wheelwell.
-> >No leaks last year but I want to deal with this while I have the gear
apart
-> >to install die springs. My question is are rivets really neccessary to bond
-> >a doubler to the inside of the wheel well side skin. I would need to get a
-> >right angle drill if I wanted to get holes in there but it would be fairly
-> >easy to clamp it in place with some wedges. I think I'll use pro-seal for
-> >the bonding agent instead of sikaflex. Any comments?
-> >Drew
-> Drew
At 10:09 PM 6/30/2007 -0900, you wrote:
over?
Ray
Mine is similar to what Ken described and the springs are the same as both
Ken and Bob except I added a grease fitting. I installed the doublers today
about a 3" x 4" triangle on both sides of each side skin. I'm hoping that
is enough to prevent further cracking. I think the proper fix would be to
remove the bottom rear skins and instal a patch that goes all the way to
the bulkhead. Also I think that maybe there should be some more structure
tieing the wheel well to the bulkhead right now it's just .020 angle plus
the bottom skin.
put
are,
-> >Walter
Of Drew
-> >Dalgleish
wheelwell.
apart
bond
get a
fairly
-> >Drew
-> Drew
Angus McKenzie
Post by Angus McKenzie » Sun Feb 19, 2012 12:12 pm
Hi Drew
My floats are cracked like yours.
Have to retighten the front drag wires today, landing and take-off from Lake
Erie yesterday with waves near 1 meter and got pounded.........Angus
Sent: Saturday, June 30, 2007 9:35 PM
Hmmm, you guys have me worried now. I am going to have a closer look at
mine. I assume these cracks and creases are only visible from inside the
wheel well. There is a lot of grease and crap in there on mine, and haven't
had a close look for a while. However, I have had my fair share of rough
water landings and take-offs, as well as been on some rough landing strips.
I will say, though, that I have not had to retighten any of my drag wires
since the first tightening after the initial flights on floats many years
ago (400+ hours). Also, my rear float hard points, which don't have that
doubler, have not shown any sign of buckling on the side. And I do check
them real carefully every time after a rough water landing.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Angus
McKenzie
Sent: Tuesday, July 03, 2007 5:59 AM
Hi Drew
I thougt I did a good inspection at the end of the season last year but
missed it completely. If the gear is down it's hard to see the cracks from
below but you can see them by looking through the inspection hatch. The
cracks were only on the left float and my rear hard points have no damage
yet either. As for rough water I try to avoid waves over a foot high. I
scared myself last year on lake huron in big waves when I got sideways in
the surf and had gallons of spray coming in through the open window. I was
soaked and there was water sloshing around on the floor.
McKenzie
Hi Drew
Hi Angus Were you scouting Port Dover for docking space on the 13th? :)
At 08:59 AM 7/3/2007 -0400, you wrote:
Hi Drew
