Interesting. :-)
Rick Muller
(303) 664 9219 Home
(303) 641 6623 Cell
rickhm@comcast.net
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jim
Cole
Sent: Friday, June 01, 2007 10:41 AM
Subject: [rebel-builders] Re: Notam
I was checking out the weather and Notams for my area and found this Notam
interesting for those in Southern Ontario.
CZYZ PURSUANT TO SECTION 5.1 OF THE AERONAUTICS ACT, AIRSPACE
WITHIN 1.5 NM CENTERED AT 435941N 801550W (APRX 3 NM SW
SHELBURNE/BURBANK FIELD AD, YMS 220/12) SFC TO 7000 FT MSL
IS RESTRICTED DUE HIGH POWERED ROCKET LAUNCH ACT. NO PERSON
SHALL OPR AN ACFT WITHIN
THE AREA DESCRIBED UNLESS AUTH BY THE CONTROLLING AGENCY AT
905-441-2464 OR 647-221-0581. 1400/2200 DLY
0706091400 TIL 0706102200
Now it's not until the 9th and 10th of June but - be on the look out for the
"high powered rocket"
Jim 333R
On 6/1/2007 1:20 PM, "steve whitenect" <srwhitenect@hotmail.com> wrote:
aGarry
If u don't have an ANR head set, get divorced and buy a good set. I was/am
hearingcommercial pilot and if it wasn't for a good David Clark ANR set, my
ramble.would be alot worse than what it is. It's worth the money and if u have a
couple more bucks, get the Bose.
Steve W 637R
Subject: Re: [rebel-builders] Door Windows
Date: Thu, 31 May 2007 21:47:26 -0600
Thanks Ron. It will be done. Both sides and hopefully prior to the
_________________________________________________________________Garry
Ron Shannon wrote:way.In the booklet "How to Soundproof Light Aircraft" available from
http://www.soundproofing.org (also via ACS) they are very clear that one
of the the best things you can do to reduce noise is use thicker window
material.
Garry Wright wrote:
Windows Live Hotmail with drag and drop, you can easily move and organize
your mail in one simple step. Get it today!
www.newhotmail.ca?icid=WLHMENCA153
