Bob, 612e
Original Message:
Date: Tue, 22 May 2007 17:13:06 -0500
Subject: Re: [rebel-builders] "Level Flight Attitude"
I used the bottom of the cabin or sidesill. The W&B section in the manual
shows a drawing of the airplane with an extending reference line from this
cabin sill being parallel with the ground.
Mike Betti
Sent: Tuesday, May 22, 2007 7:26 AM
Subject: [rebel-builders] "Level Flight Attitude"
Hi,
The Weight and Balance section in the Elite manual says to put the
aircraft
in a level flight attitude. Yet, no where does it say what that is - or
at
least if its there, I haven't found it yet. For certified aircraft, the
TCDS defines how to get a given aircraft in the "level flight attitude"
(e.g., plumb from one point to another point). Since the bottom of the
wing
is a few degrees up from the cabin floor, I would tend to think when the
cabin floor is level (for and aft), the aircraft is in the "level flight
attitude" w.r.t. pitch ... but would like to actually read that somewhere.
Asside from getting the W&B correct, this impacts calculating where the
step
goes when rigging floats. Because the distance is a fair distance between
the bottom of the wing and the float step, A plumb line down from a given
%MAC (e.g. 45%) from a improperly rotated aircraft will result in the step
NOT being where you planned to put it. So, what defines the "level flight
attitude" for an Elite? ... and other Murphy derivitives?
Cheers, Bob 612e
mail2web LIVE
