Hello Jean,
If I understand your question correctly, I've found that as long as you're
drilling #40, using a lexan template (I use 0.040 lexan) the holes come out
fine. If I have to go to #30 (due to the underlying structure already being
at #30 for instance) I think using a hole finder creates a more accurate
finished product.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jean
Poirier
Sent: Tuesday, April 24, 2007 12:44 PM
Subject: [rebel-builders] inner floor
Hello
When I made the fuselage inner floor, I used the "lexan technic" instead of
put the
inner floor on the outer skin for holes matching. For the cabin floor, the
sheet
are different (3 pieces vs 1 piece), the inner floor is longer at the cabin
front, and there is a angle (inner always shorter than outer), could I use
the "hole matching technic" or it is better to use the "lexan one"?
p.s.: french to english translation have been difficult
Hi Jean: I would be surprised if a "matching" technique worked for either
floor area due to the fact of the varying angles of the various channels.
The lexan sounds like a pretty accurate method. My own method was simply to
start with 4 corner holes with floor in place - remove the floor panel -
connect the holes, measure and transfer centerlines. I have done this method
3 times now with great success. Bob J Rebel 652,725,192/731
From: "Jean Poirier" <jean.poirier@oxyportneuf.com>
Sent: Tuesday, April 24, 2007 2:44 PM
[quote]Hello
put the
sheet
cabin
p.s.: french to english translation have been difficult.
Jean
Rebel 747R
Jean Poirier
Pr
[quote]Hello
put the
sheet
cabin
Jean
Rebel 747R
Jean Poirier
Pr
That is how I do it as well Jean! Pick a starting point and measure for
channel locations. Mark them out and start drilling.
Sent: Tuesday, April 24, 2007 3:15 PM
Subject: Re: [rebel-builders] inner floor
[quote]Hi Jean: I would be surprised if a "matching" technique worked for either
method
[quote]Hello
put the
sheet
cabin
use
Jean
Rebel 747R
Jean Poirier
Pr
method
[quote]Hello
put the
sheet
cabin
use
Jean
Rebel 747R
Jean Poirier
Pr
What is the tire size for the outback tailwheel option on the moose?
Rick
Rick
floor,From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
Date: Tue, 24 Apr 2007 17:39:35 -0400
eitherHi Jean: I would be surprised if a "matching" technique worked forchannels.floor area due to the fact of the varying angles of the variousinsteadThe lexan sounds like a pretty accurate method. My own method was simply
method
Hello
When I made the fuselage inner floor, I used the "lexan technic"of
put the
sheet
cabin
use
Jean
Rebel 747R
Jean Poirier
Pr
Hi Rick,
The outback tailwheel for the Moose is 11X 4 X 5
Nan
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Rick Johnson
Sent: Tuesday, April 24, 2007 3:28 PM
Rick
Nan
Rick
simply to start with 4 corner holes with floor in place - remove the
floor panel - connect the holes, measure and transfer centerlines. I
Hello
put the
sheet
the cabin front, and there is a angle (inner always shorter than
outer), could I use the "hole matching technic" or it is better to
Jean
Rebel 747R
Jean Poirier
Pr
