Found the update on the Murphy site! Thanks!
Rick Muller
(303) 664 9219 Home
(303) 641 6623 Cell
rickhm@comcast.net
sa@dcsol.com
Sent: Tuesday, April 24, 2007 7:38 AM
Subject: [rebel-builders] RE: MOOSE: Aileron travel
What is the date on the manual? They changed it in 2002 - it shows the
horn (the one on the end of the tube that comes out of the wing) set at zero
degrees or vertical.
On 4/23/2007 4:12 PM, rickhm@comcast.net wrote to rebel-builders:
-> I read through what I could find on the list regarding the controls for
-> moose/2500. My manual indicates that the angle between vertical and the
-> horn for the torque tube is 50 degrees. Apparently there has been some
-> variation here, others indicated 54 degrees. When I move the stick left
-> right I see interference between the push rod and the horn of the torque
-> tube as it pushes the horn forward. I do not get full travel!
-> The next issue is what is full travel? I cannot find in the manual what
-> travel of the aileron should be? What are others seeing?
-> Rick Muller
-> (303) 664 9219 Home
-> (303) 641 6623 Cell
-> rickhm@comcast.net
