Hello Bob,
I think that bearing was an optional support that someone came up with. I
don't think there's a service bulletin on it. You might check Scott
Aldrich's site at www.goflyamoose.com and look under completions to see if
there are any pictures of this modification.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Robert
Johnson
Sent: Tuesday, March 20, 2007 6:59 AM
Subject: [rebel-builders] Aileron Tip Support
I had seen on the Murphy site (before it was changed) a bearing support
added on the wing tip rib to support the outboard end of the aileron spade:
Can anyone advise if this is necessary or was this before the wing tip hinge
support modification. Thanks. Bob J Moose 226 (RH wing almost complete)
