[rebel-builders] What comes with the "window kit"?
Dale Fultz
Post by Dale Fultz » Sun Feb 19, 2012 11:56 am
Eddie the backers for the windows actually come with the fuselage kit...When
you order the optional windows thats all you get.. Dale SR-033 N269DF
Charlie Starr
Post by Charlie Starr » Sun Feb 19, 2012 11:56 am
I got "window kits" sometime back - came with no glass, only frames. I used
lexan from home supply and it worked well. I used all side window frames,
but did not install the overhead eyebrows - sort of wish I had - at least
put in the two forward overhead ones - in fact, may retrofit these.
Visibility in turns is somewhat restricted without them.
Charlie Starr SR N96CS
Sent: Sunday, March 11, 2007 1:23 PM
Subject: [rebel-builders] What comes with the "window kit"?
I just got my smoked window kit. Just the windows. Does anyone know if
you are supposed to get some frames with the windows?
Eddie Moran
SR228
N240MM
Bored stiff? Loosen up...
Download and play hundreds of games for free on Yahoo! Games.
Nancy Puff
Post by Nancy Puff » Sun Feb 19, 2012 11:56 am
Hi Eddie,
Hope everything is going well with you.
When you order the bubble windows that is all you get.
If you need the frames, you can get them from Murphy, they should have
told you this when you ordered the windows, or I should have.
You will need the side window doubler kit only there is nothing for the
doors.
Say hi to Doug for me.
Nancy Puff
Eddie Moran
Sent: Sunday, March 11, 2007 11:24 AM
Eddie Moran
SR228
N240MM
Post by Mike Kimball » Sun Feb 19, 2012 11:56 am
If you are talking about the two forward-most eyebrow windows on a Super
Rebel you won't need frames or lexan. They are underneath the top part of
the windshield and all you need is to cut two holes in the roof skin. These
are the ones nicely positioned to make it easier to look for airplanes above
you when making turns.
044SR
Charlie Starr
Sent: Sunday, March 11, 2007 5:08 PM
Subject: Re: [rebel-builders] What comes with the "window kit"?
Eddie Moran
SR228
N240MM
Dale Fultz
On Murphy's site under accessories it list the windows and specifically says
"Does not included doublers". but they are pictued with the windows...
Nancy Puff
Hey Dale,
I did that lol
It shows how they fit with the bubbles :)
Nancy Puff
Dale Fultz
Sent: Tuesday, March 13, 2007 8:35 PM
says "Does not included doublers". but they are pictued with the
windows...
