You're right - you will want to add the extra row of holes for
attachment of the wing skin, outboard of your new end rib
position - #2 . You can then trim the tank skin down to the
smaller size - and save some weight ! :-)
This would mean cutting less of the wing skin away ...
and filling those extra skin holes with rivets later, I guess ...
http://www.prosumers.ca
On Sunday 18 February 2007 17:18, Charlie Eubanks wrote:
Hello All
I plan to certify my Rebel at 1320 Lbs. so I will only be using two tank
bays (15 Gal's) per side. I am getting ready to transfer the holes to the
tank covers from the wing skins which are pre-drilled to use all three tank
bays. I assume the preferred procedure would be to use the full size tank
covers and duplicate the two extra rows of holes at the tanks outboard rib
(#3)
Charlie E. 802R
