[rebel-builders] RE: Rebel- Wing leading edge skin
Keith Leitch
Post by Keith Leitch » Sun Feb 19, 2012 11:52 am
Sorry about that terminology. I should have said the
stringer nearest the front of the wing. My kit is 661
and the leading edge skins are marked L or R and have
the inspection hole in them already. Chock up a
brownie point for Murphy!! I also got a reply from
Darryl and he stated there shouldn't be a gap. The gap
is 2 1/2" whereas the average in that area is 1 1/4".
I already marked it and will drill it.
Keith
--- bransom@dcsol.com wrote:
Keith,
Not sure my reply is of much use because my kit is a
little older, 496R,
before they showed the mid-wing inspection hole. As
well, I'm not positive
what you mean by "nearest stringer to the tip".
However, on my wing skins
there were no gaps in pre-punched holes anywhere.
That includes LE skins
and main skins. The only differences are change in
pitch (rivet spacing)
and as you know, that is how you determine
left/right, inside/outside,
root/tip. I wonder if you might look at how and
where the inspection hole
doubler will tie in to the stringers. Even here
though, I used the regular
spacing of the prepunched skin holes.
-Ben
On 2/16/2007 1:31 PM, im_planecrazy@yahoo.com wrote
to rebel-builders:
I am currently installing the stringers on the
leading
edge skin. On the side that faces the bottom of
wing...nearest stringer to the tip....there seems
be a space between the predrilled holes where one
hole
appears missing. This is about 5 inches over and 5
inches in from the large inspection hole. It is
missing on both skins. Is there suppose to be a
hole
there and it was not punched at the factory? Or is
this space left unrivetted for a reason?
Keith R661
____________________________________________________________________________________
Finding fabulous fares is fun.
Let Yahoo! FareChase search your favorite travel
sites to find flight and
hotel bargains.
List archives located at:
https://mail.dcsol.com/login
Expecting? Get great news right away with email Auto-Check.
Try the Yahoo! Mail Beta.
http://advision.webevents.yahoo.com/mai ... tools.html
