There is no need for the stringers to extend past the tip. The reason that
the left wing LE stringers are cut 3/4 and the right only 3/32, is because
the reinforced LE root rib faces inboard on the left wing, and outboard on
the right. However you measure it, just make sure the inboard ends of all
the stringers on both wings will fit inside the root rib.
Jesse
_________________________________________________________________From: Keith Leitch <im_planecrazy@yahoo.com>
To: Murphy Rebel Builders <rebel-builders@dcsol.com>
Subject: [rebel-builders] Rebel-Wing stringers
Date: Sun, 11 Feb 2007 21:57:20 -0800 (PST)
I am assembling the stringer to the Right wing and the
manual states to trim the stringers 3/32"for the six
stringers on the leading edge. Chapter 10.6.6
Then there is a note stating to trim the left wing LE
stringers by 3/4" and under that there is a diagram
showing 4 stringers behind the main spar offset by
3/4". Is this for both wings or just the left?
I already assembled the bottom skin with the stringers
flush to the edge before I realized that this diagram
may be for both wings. Is it alright (if needed) to
just cut 3/4" off of the on stringer or is it needed
to extend out the tip end for any reason?
Thak you,
Keith R661
____________________________________________________________________________________
Sucker-punch spam with award-winning protection.
Try the free Yahoo! Mail Beta.
http://advision.webevents.yahoo.com/mai ... _spam.html
Check out all that glitters with the MSN Entertainment Guide to the Academy
Awards
