[rebel-builders] Wing cut-outs for fuel tanks.
Post by Drew Dalgleish » Sun Feb 19, 2012 11:42 am
At 04:22 PM 2/3/2007 -0600, you wrote:
Can anyone tell me the exact location of the lines for the wing skin
cut-outs for the wing tanks? I have e-mailed and phoned MAM with no reply
in the past five days. I need to know the location of the lines parallel to
the tank bulkheads for both the top and bottom skins. I don't find it very
clear at all in the manual. It is shown in figure 10.10.12 section 0.10
Wing Assembly. The diagram doesn't show the line of rivet holes for the
tank bulkheads as far as I can see. Does anyone have an approximate
distance from the leading or trailing edge of the skin?
Bill Londry
767R
The size of the top and bottom tank skins has changed a few times over the
years so I'm not surprized the manual hasn't kept up. I'd just use even
spacing while maintaining enough edge clearance.
