[rebel-builders] bending aluminium..
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:39 am
Yes Jean and actually will be stronger when bent 90 degrees to the grain
direction. The ST-31's are done that way for convenience to get 6' lengths.
Older kits only had 3 lengths of ST-28's and they are the stab and fin
spars. There was never any supplied to do the fuselage except the one piece
to do the middle/double seat belt attach channel.
Sent: Friday, February 02, 2007 7:27 PM
Subject: [rebel-builders] bending aluminium..
One of the Ontario mod is to replace ST-31 by ST-28 for the door frame...
If I do it that way, I will be short of ST-28 later and I will have a
overstock of ST-31. Like I told before, I will make doubler out of .020"
scrap material and double those sill. My question:
The "grain of the aluminium" in ST-31 is longitudinal, but if I use the
"scrap" I have the grain of the doublers will be "in the other way"...
Because it is just a doubler, is it OK?
Jean
Rebel 747R
jean.poirier
Post by jean.poirier » Sun Feb 19, 2012 11:39 am
Thanks again Wayne...
Jean
On Fri Feb 2 19:39 , 'Wayne G. O'Shea' <oifa@irishfield.on.ca> sent:
To: rebel-builders@dcsol.com>
Jean
Rebel 747R
jean.poirier
Another question:
As I see, those sill made of ST-31 are parts that I will "see" from the inside. So If one day in the future, I want to put a "finish" (carpet,
rubber,etc.) I should rivet the ST-31 wiht the doubler with flush rivets...?
Jean again...
On Fri Feb 2 19:45 , <jean.poirier@oxyportneuf.com> sent:
Jean
On Fri Feb 2 19:39 , 'Wayne G. O'Shea' oifa@irishfield.on.ca> sent:
Jean
Rebel 747R
