[rebel-builders] Fuel tank rivets--mandrel problem
Post by Bob Patterson » Sun Feb 19, 2012 11:38 am
Hi Ted !
Very likely a bad bunch of rivets - one problem with buying from a
jobber ...... They can mix batches from different manufacturers !
This 'breaking off high' problem was the reason for Murphy switching
suppliers a few years back !
You've got the best solution - "Dremel is your friend !" ;-)
(Possible a grinder, after the cutter ....)
http://www.prosumers.ca
On Friday 02 February 2007 17:14, Ted Waltman wrote:
I riveted my bottom fuel tank skin on yesterday using RV-6403 tank rivets.
During this (messy <grin>) process, I noticed that perhaps as many as 30% of
the mandrels did not break off. I adjusted my pneumatic rivet gun as tight
as it would go. I also ground down the rivet tip on the gun as far as
practical. I even tried a manual puller with about the same % problem
results.
I held up a RV-6403 rivet to a standard RV-1410 rivet. The mandrel on the
RV-6403 rivet was 1/8" or maybe 5/32" shorter than the mandrel on the
RV-1410's. So therein lies the problem (or so it seems).
When I first saw this mandrel issue happening, I got a bunch of scrap metal
and put some 6403 rivets in. Didn't appear to matter whether I was going
thru a total of .060 or as much as .080 total thickness-I still had maybe
30% of the mandrels fail to properly break off. The good news is, on the
tests, the rivet tails appeared to be the same regardless of whether the
mandrel broke off or not. In other words, I'm quite confident that the
rivets are Ok as installed on the tank skin.
Did I get a bad batch of rivets? I don't know. What a pain, though, to
have to go back and [carefully] use a cutting wheel to take off those
mandrels that didn't properly break off.
I posted pictures of the problem in area 106 S/M wings
Moose N384JP
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 11:38 am
...I received those rivets from Murphy Aircraft.
Patterson
Sent: Friday, February 02, 2007 10:32 AM
Subject: Re: [rebel-builders] Fuel tank rivets--mandrel problem
Hi Ted !
tight
results.
metal
Moose N384JP
If it was a few years back, they had a replacement offer ....
If not, and you have a lot more, best to let them know !
Wouldn't think that the mandrel length should be a problem,
as long as it gets gripped firmly by the gun ....
Patterson
Hi Ted !
tight
results.
metal
Moose N384JP
Ted Waltman
I received them a couple of years ago (?) when Darryl had that $500 credit,
parts and proseal deal for owners with leaking tanks. So, you're probably
right that they were part of an old batch. Oh well, the process is done for
now...at least until I fill the tanks with fuel and then find the inevitable
leaks <grin>. I did send a separate email to Darryl to document this issue
earlier this morning. Thank you for your input.
Patterson
Sent: Friday, February 02, 2007 10:51 AM
Patterson
Hi Ted !
rivets.
30%
tight
results.
metal
going
maybe
Moose N384JP
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:38 am
The replacement was for RV1410's made by Rivets Unlimited, that had the
"gold" mandrels. Not on the RR64xx series of tank rivets.
Sent: Friday, February 02, 2007 12:50 PM
Patterson
Hi Ted !
rivets.
30%
tight
results.
metal
going
maybe
Moose N384JP
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:39 am
Went AWOL for some reason.
Common issue with Mattics RR6402/6403. Sometime they all go good and
sometimes a few handfulls that the mandrel breaks proud. The rivets are
all pulled well in either case. Cut wheel and a quick touch up. I had only
a couple in over 13,000 break proud doing Howard's floats. Other times you
can get more than that in a single tank skin. They are VERY grip sensitive
for allowing the notched area to break.
Sent: Friday, February 02, 2007 12:32 PM
Hi Ted !
rivets.
30% of
tight
results.
metal
going
maybe
Moose N384JP
sometimes a few handfulls that the mandrel breaks proud. The rivets are all
pulled well in either case. Cut wheel and a quick touch up. I had only a
couple in over 13,000 break proud doing Howard's floats. Other times you can
get more than that in a single tank skin. They are VERY grip sensitive for
Hi Ted !
rivets.
tight
results.
metal
Moose N384JP
Jean Poirier
Post by Jean Poirier » Sun Feb 19, 2012 11:39 am
Hello Ted
I had the same problem with may be 15-20% of the/$%/$?"% rivets of the gas
tank... I hate those rivets
Jean Poirier
Pr
Kim Kimball
Post by Kim Kimball » Sun Feb 19, 2012 11:42 am
Don't do your first check for leaks with fuel. It will make it harder for you to repair. Use one of the many methods using air that have been discussed on the list.
044SR
Date: Friday, February 2, 2007 8:58 am
Subject: RE: [rebel-builders] Fuel tank rivets--mandrel problem
$500 credit,
probablyright that they were part of an old batch. Oh well, the
process is done for
inevitableleaks <grin>. I did send a separate email to Darryl to
document this issue
Of Bob
Patterson
Behalf Of Bob
Patterson
Hi Ted !
from a
manufacturers !
rivets.
many as
30%
gun as
tight
as far as
problem> > results.
mandrel on
on the
of scrap
metal
I was
going
still had
maybe
is, on
whether the
that the
though, to
off those
Moose N384JP
Post by Ken » Sun Feb 19, 2012 11:42 am
FWIW as per past discussions I use a regulator to reduce the air
pressure to the minumum required to pull rivets (especially if proseal
is involved). Some guys have said that they believe that minimizes this
broken mandrel problem. I haven't had the problem with any rivets from
any supplier so maybe the technique helps or maybe I'm just lucky. Also
sometimes in tight locations I put a spacer between the gun and the
rivet and still don't have a problem so I think this is more likely a
qualtiy problem than a mandrel length issue.
Jean Poirier wrote:
[quote]Hello Ted
Jean Poirier
Pr
