Hi Jean: Nothing wrong with your English - It is a hell of a lot better then
my French and I salute you for your great efforts. The only problem with the
door sill using the standard St 31, was the top surface could get dented
easily climbing in and out and loading/unloading cargo. I also installed a
long strip of .020 on top when I did my first Rebel and wrapped it up the
radius corner sections. - Worked just fine. Bob J - Rebel 192/731
From: "Jean Poirier" <jean.poirier@oxyportneuf.com>
Sent: Wednesday, January 31, 2007 8:35 AM
Subject: [rebel-builders] door sill....
[quote]Hello,
One Ontario mod call for replacement of ST-31 of door sill by ST- ??
(part
number is at home!) but I will be over stock with the ST-31 and short of
ST-??. But I do have some strip of .020" than I can bend and make
doubler.
In which way the ST-31 is too weak? From the outside to inside (let say
horizontal) or from the top to the floor (let say vertical)?
P.S.: I am sure some of you have good laugh with my English!
Jean
Rebel 747R
Jean Poirier
Pr
