Should you move your firewall back 3"? A letter from D
Should you move your firewall back 3"? A letter from Darryl Murphy.
Post by Mike Davis » Sun Feb 19, 2012 11:38 am
I just received the following letter from Darryl regarding his views on moving the firewall back 3". He asked that I share it with all the builders on the list. I have also posted this letter as a PDF file in the file library.
https://mail.dcsol.com/file/area206/let ... arryll.pdf
TO ALL REBEL BUILDERS
Recently there has been a lot of discussion on the need to move the fire wall back 3" when installing a 320 engine into a Rebel. There are proponents in each camp as well as a considerable amount of false information out there.
Lyc 320 powered Rebels have now been flying for 15 - 16 years and there are many new and older builders who do not know or have forgotten my reasons for moving the firewall back. Therefore, I would like to re-hash my reasoning.
First off; I would like to say that although many people believe the Rebel was originally designed for the 80 hp 912 Rotax, this is not so. It was really originally designed for the 108 -125 hp 235 Lycoming engines.
The use of the 80 hp Rotax 912 was for marketing. We wanted to show the public that it would fly well on 80 hp. In the home building industry, particularly in North America, it is believed by many builders "That if some is good, more is better", especially when it comes to horse power. If the first Rebel had started with a 235 or 320, I'm sure we would now be seeing 540 powered Rebels. I know most of you would think that ridiculous but I have fielded questions about the 470 Continental, 540 Lycs, 220 hp Franklins, a number of turbines and of course many automotive conversions from 80 hp to 300 hp for Rebel installations.
The idea behind moving the firewall back 3" for the heavier engine is very simple. It is done to put the CG range in a more favourable position for good flight characteristics. I am not talking about the safe CG envelope of the aircraft but rather the good flying CG range within the safe CG envelope of the aircraft.
Over the years, I have had the opportunity to fly in many variations of Rebels and I have never been in one that flys badly. However, those that were the most delightful to fly, were those built lightly with a more aft CG (25% - 30%). This was never more apparent as when Robin and I were doing spin testing. The test aircraft was set up with a heavy lead weight within a large diameter ABS pipe. The ABS pipe was positioned between the seats and extended about
