Everbrite test
eric.r
Everbrite test
Post by eric.r » Sun Feb 19, 2012 11:30 am
OK guys (and gals ...) I just had four aluminum scuba tanks stripped and
polished during their hydro tests. I am going to coat them with the everbrite
and subject them to salt water diving, bright sun, rough handling by others,
bumps, scrapes, expansion and contraction due to filling and temperature
changes,etc. These are 6061 T-6, and have a slide on plastic tank boot to
help hold in moisture (tanks typically corrode under them).
If it holds up under such use, the floats should be a cake-walk. I'm also doing
my Jeep Cherokee plastic bumper / side panels for a test of high speed
abrasion resistance in the Spring rainy season.
YES, it is scuba diving weather here ... warm water, blue sky Christmas
wishes from Sunny SW Florida!
