[rebel-builders] Winter proofing Floats
Richard Wampach
Post by Richard Wampach » Sun Feb 19, 2012 11:26 am
Al Could be a big reason for your concern. I would be a little hesitant
to try most solvents on the sealant in the floats; you might do a sample
and see how it reacts before trying it in the floats.
Dick Wampach, SR-108
Alan Hepburn
Sent: Saturday, November 18, 2006 6:38 PM
Subject: [rebel-builders] Winterproofing Floats
I am concerned that any moisture in the seams of my flats may freeze and
open them up over winter. I am thinking of adding either a little
antifreeze or a little winshield washer fluid to each compartment. The
washer fluid is cheaper and probably more environmentally friendly. I
wonder if either fluid will soften the Sikaflex caulk in the float
seams. Any ideas?
Al Hepburn
