Well...I've gone thru all the pictures I can think to use...around 1200 of
them...and Daryl's busy writing code to upload them into a type of website
format so you DON'T have to click each file #..look at it..hit the X to get
rid of..try and remember where you were for the next picture etc. Once he
has that together I will then go thru them all again to see if I need to add
any explanation text to any pictures. From that we'll see how many hours get
expended on set up and how long each disc is going to take to burn, while
adding the copy deterrent to each disc, before I can say for sure we can
stick to this price...but for now I am ball parking $175cdn including CD
case/mailing envelope, postage and will include applicable taxes for
simplicity.
All orders will be via Visa or Mastercard credit cards only and note that
all pictures are covered by copywrite laws and as such their reproduction,
on media file or paper, for anything other than personal use in your shop is
not allowed. No posting in any internet location without my expressed
written permission. Anyone ordering agrees to these stipulations or don't
bother ordering a disc please.
I'll let you know when we have the final draft. Should be very soon. Anyone
that wants to be contacted directly to order when we are done please send me
an email directly to oifa@irishfield.on.ca
If this amphib float build CD is successful. The next one will be a Rebel
Fuselage Build CD. After that with a lot of manual picture scanning we may
be able to do Rebel wings/control surfaces.
BTW, this float build CD covers the following:
Float build - from kit to ready to mount
Main gear axle drill for grease
Torque plate mods for easy main wheel install
Pump out adapter for beckson pump to fit MAM's tiny cups
Spreader bars
Mounting struts to Rebel
Rigging details shots on various Rebels
Flywires
Alternate Hydraulic installaton with solid lines
Elite installation to CLAMAR 2200's
Rudder pedal gust lock
Water rudder bar that's required with Clamars to get full deflection of
water rudders
Ventral Fin construction for Rebel/Elite
Brake pedal cylinder mounting mod
...and other bits and pieces.
Wayne O'Shea
Irish Field Aviation
1800 Amphibious Float - Build CD
THat is awsome Wayne. What a great resource!
On 11/11/2006 8:36 PM, oifa@irishfield.on.ca wrote to rebel-builders:
-> Well...I've gone thru all the pictures I can think to use...around 1200 of
-> them...and Daryl's busy writing code to upload them into a type of website
-> format so you DON'T have to click each file #..look at it..hit the X to get
-> rid of..try and remember where you were for the next picture etc. Once he
-> has that together I will then go thru them all again to see if I need to add
-> any explanation text to any pictures. From that we'll see how many hours
get
-> expended on set up and how long each disc is going to take to burn, while
-> adding the copy deterrent to each disc, before I can say for sure we can
-> stick to this price...but for now I am ball parking $175cdn including CD
-> case/mailing envelope, postage and will include applicable taxes for
-> simplicity.
-> All orders will be via Visa or Mastercard credit cards only and note that
-> all pictures are covered by copywrite laws and as such their reproduction,
-> on media file or paper, for anything other than personal use in your shop is
-> not allowed. No posting in any internet location without my expressed
-> written permission. Anyone ordering agrees to these stipulations or don't
-> bother ordering a disc please.
-> I'll let you know when we have the final draft. Should be very soon.
Anyone
-> that wants to be contacted directly to order when we are done please
send me
-> an email directly to oifa@irishfield.on.ca
-> If this amphib float build CD is successful. The next one will be a Rebel
-> Fuselage Build CD. After that with a lot of manual picture scanning we may
-> be able to do Rebel wings/control surfaces.
-> BTW, this float build CD covers the following:
-> Float build - from kit to ready to mount
-> Main gear axle drill for grease
-> Torque plate mods for easy main wheel install
-> Pump out adapter for beckson pump to fit MAM's tiny cups
-> Spreader bars
-> Mounting struts to Rebel
-> Rigging details shots on various Rebels
-> Flywires
-> Alternate Hydraulic installaton with solid lines
-> Elite installation to CLAMAR 2200's
-> Rudder pedal gust lock
-> Water rudder bar that's required with Clamars to get full deflection of
-> water rudders
-> Ventral Fin construction for Rebel/Elite
-> Brake pedal cylinder mounting mod
-> ...and other bits and pieces.
-> Thanks,
-> Wayne O'Shea
-> Irish Field Aviation
-> www.irishfield.on.ca
get
-> simplicity.
Anyone
send me
-> Spreader bars
-> Flywires
-> water rudders
-> Thanks,
-> Wayne O'Shea
