[rebel-builders] Good advice from older builders (sorry long
jtpackard
[rebel-builders] Good advice from older builders (sorry longer then I plann
Post by jtpackard » Sun Feb 19, 2012 11:26 am
Thanks Dale,
My nose bowl is the same front, (top and bottom) cowling that you got from
MAM. I'll take a look at that four door design you mentioned.
Tom
Sent: Monday, November 06, 2006 9:07 AM
Subject: Re: [rebel-builders] Good advice from older builders (sorry longer
then I planned it)
Yes Tom there are important things need changed but as far as making a lot
of advancements and changes (structure problems or safety items by all
means
do) I wonder if all the extra time is really worth it in the end.
The nose bowl you ask about , what are you using the top and bottom
full cowling or just the front fiberglas nose bowl if you are using just
front nose bowl, I went into the rebel builders site under rebels and got
ideas from the guys that used the nose bowls for there Rebels. The four
door
cowl design worked well for me. . Dale SR-033 N269DF
Checked by AVG Free Edition.
Version: 7.1.409 / Virus Database: 268.13.28/518 - Release Date: 11/4/2006
--- http://USFamily.Net/dialup.html - $8.25/mo! -- http://www.usfamily.net/dsl.html - $19.99/mo! ---
