Holds Air ...was Re: Test
Wray Thompson
Post by Wray Thompson » Fri Feb 17, 2012 5:46 pm
Well just to keep some forum activity going - my tank has held air for 2 days now, so the
second wing should be finished and put away by the end of the wing and I can (finally!)
start on the fuselage.
Sure hope these wings hold gas ...I've got them both sealed and haven't even used one can
of proseal ..mind you I did use the better part of a pint of brushable to coat all the
rivets and seems before putting the top skins on. BTW for anyone keeping there proseal in
the freezer and wondering how long it might keep, I've had mine in there since 94 and it
worked just fine ..even after being out and back in for the first wing this time last
year.
Probably quiet here as everyone's gone to SNF maybe? CU ...Wray
Rick Harper wrote:
Works OK here in "OZ " !!!!!!
To: murphy-rebel@dcsol.com <murphy-rebel@dcsol.com>
Cc: flying-rebels@dcsol.com <flying-rebels@dcsol.com>;
rebel-ramble@dcsol.com <rebel-ramble@dcsol.com>
Date: Wednesday, 5 April 2000 19:59
Subject: Test
No messages in the last 2 days, just thought I'd test things.
The Flying Rebels List is for the discussion between
builders and owners of complete/flying Murphy Rebel
aircraft. Archives located at:
Wray Thompson ...Rebel 306 ...home page http://webhome.idirect.com/~wrayt/
