[Fwd: Rivets]
David A. Ricker
[Fwd: Rivets]
Post by David A. Ricker » Fri Feb 17, 2012 5:46 pm
Oops! Sent this to the wrong address.
Dave R.
------ Start of attached email. Subject: Re: Rivets ------
------ End of attached email ------
David A. Ricker
[Fwd: Rivets]
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"> This is bad, I am not getting any work done!
OK, called AVDEL, they said you want a nice symetric bulb to be formed when the rivet pulls but would not commit to how far the mandrel should pull in to the barrel of the rivet.
Called Rivets Unlimited. They have the rivets we are getting from Murphy made to their spec. They say that you want a nice symetric bulb to be formed when the rivet pulls and that dome of the mandrel should not pull very far into the barrel of the rivet. I described what one of the hand/low pressure pulls looked like and he said this was what they were looking for. The head just pulls into the barrel leaving the dome of the mandrel sticking out .030 - .050" & is gripped at the edges.
He said that if it is pulled fast/hard enough that the mandrel will pull down into the barrel until the added resistance from the sheet you are riveting stops it from stretching radially then the mandrel breaks. This will leave the broken end of the mandrel protruding in thin materials.
Both Avdel & RU stated that the mandrel was designed to break at a set static loading. Adding in the dynamic action caused by the speed at which the air riveter will pull at high pressure you get into a hazy area where the loading of dynamic friction is different from static and also things under shock loading act differently than quasi-static. The load on the mandrel doesn't reach break until the barrel is deformed more than the design called for and the mandrel is pulled farther into the rivet barrel. That said, I have seen some variation in the shape of the set rivet even using low pressure (and presumably would occur by hand also....) so I am sure there is some variation in the material properties from rivet to rivet.
Well folks, there you have it, this is what I have learned this morning, I hope it is useful and it is presented with that in mind. As with any of the information you see here, you mileage may vary so satisfy youself that what you are doing is correct and then proceed!
Back to work now...
Dave R.
David A. Ricker wrote: [quote] [quote]Your following message has been delivered to the 151 members of
David A. Ricker
[Fwd: Rivets]
I didn't go into the rivet fit when I called, I guess for a couple of reasons. First I was looking for info and didn't want to pick on them at that point and more selfishly, we have something like 20,000 of these things so it won't make a big difference for a while yet... Not a bad idea though to let them know that they could improve the product.
The problem looks to me like the dies they use to form the barrels could have a better fit but this would probably involve spending five figure sums so they would probably not want to do that right away! I agree (and Francine even more so!) that it would be easier on the fingers if these things would be easier to put in place.
Yeah, I charge by the hour too but this doesn't pay too well so I had better get back to work. Hope what I have done here helps.
Dave R.
PS Phil & Lisa, this is just what this group is all about, working together we accomplish more than by ourselves. Just look at the talent & experience we have here, I'm sure we or someone one of us knows can answer about any question we might come up with.
Wayne G. O'Shea wrote:
David, with that all said, I guess I need to slow down my work pace!!!!!! This is a good thing I guess, because I charge by the hour!!! When you had Rivets Unlimited on the phone, did you complain they make them oversize and your fingers are killing you from putting them in the holes! Blues skies,Wayne
From: David A. Ricker <ricker@dbis.ns.ca (ricker@dbis.ns.ca)>
To: Murphy Rebel Builders List <murphy-rebel@dcsol.com (murphy-rebel@dcsol.com)>
Date: Wednesday, March 22, 2000 12:04 PM
Subject: Re: [Fwd: Rivets]
Back to work now...
Dave R.
David A. Ricker P. Eng.
DARTEC Engineering Inc.
Fall River, Nova Scotia
Canada, B2T 1E8
ricker@dbis.ns.ca
LisaFly99
[Fwd: Rivets]
Post by LisaFly99 » Fri Feb 17, 2012 5:46 pm
Thanks for the info on rivets.
Phil&Lisa Smith #460 N414D
[Fwd: Rivets]
Post by Wayne G. O'Shea » Fri Feb 17, 2012 5:46 pm
Blues skies,
Back to work now...
Dave R.
[Fwd: Rivets]
David,
I purchased my Lemon Twist Yellow Super Bird in 1989. It is a (440 - 4barrel Super Commando) Texas car with 56,000 miles on it! I totally corrected it back to original (right back to the spring clamp style hose clamps on the radiator hoses). Cars were my addiction previous to aircraft and took up as many or more hours as aircraft do today! I also own a 1969 Super Bee ( 383 Magnum 4 gear -B5 Blue with white stripe and Ramcharger Hood) with 58,000 miles on it. I bought it from my Dad when I was 17. He bought it new! My wife has a 1964 Corvette. A plastic piece of junk to a Dodge Man, but that is what she wanted for a 10th anniversary gift! (that was 8 years ago).
My 2 cars get neglected now, and make it out of the garage every 2nd year or so, I just don't have the time anymore. Haven't got a clue why!!!!! I've actually been putting some thought to selling the SuperBird at Auction (or privately). It will have a Reserve bid of $75,000 Cdn on it when/if this happens! In the mean time I consider the collection my retirement fund!
Like you said, back to work!
Subject: Re: Rivets
Date: Wed, 22 Mar 2000 12:00:52 -0800
Organization: .
To: "David A. Ricker" <ricker@dbis.ns.ca>
References: <001a01bf9381$b2daa100$0732fea9@pentium-ii-266> <38D907FD.9CB9F211@dbis.ns.ca>
OK Wayne, now an off topic thought, you mentioned something about a Superbird in one of your mails, what's the story? How did you come across that rare beast? No pics on the web page?? If I had my pick of "money is no object" toys for my garage the Superbird's sister, the Daytona Hemi would be sitting there beside my F40.
[Fwd: Rivets]
Post by Bob Patterson » Fri Feb 17, 2012 5:46 pm
Thanks for all the research, guys !!
You may get a bit of piece of mind from Darryl's words - I believe he
did the original load & stress calculations based on the rivet shear
strength WITHOUT the mandrel being retained - it is a bonus ! (You <know>
how much <closer> our rivets are spaced than Zenair's ! ;-) )
Also, we have found that the mandrels will not fall out if the rivets
are dipped before inserting & pulling. The Epoxy chromate wicks right
up around the mandrel & locks it in place, as well as sealing the rivet,
so water doesn't run through....
....bobp
-------------------------------orig.------------------------------------
At 01:39 PM 3/22/00 -0800, you wrote:
Dave R.
materials.
Back to work now...
Dave R.
Canada, B2T 1E8
ricker@dbis.ns.ca
<HTML>
<BODY BGCOLOR="#FFFFFF">
<P>I didn't go into the rivet fit when I called, I guess for a couple of
reasons.&nbsp; First I was looking for info and didn't want to pick on
these things so it won't make a big difference for a while yet...&nbsp;
<P>The problem looks to me like the dies they use to form the barrels could
sums so they would probably not want to do that right away!&nbsp; I agree
<P>Yeah, I charge by the hour too but this doesn't pay too well so I had
better get back to work.&nbsp; Hope what I have done here helps.
<P>Dave R.
<P>PS&nbsp; Phil & Lisa, this is just what this group is all about,
working together we accomplish more than by ourselves.&nbsp; Just look
<P>Wayne G. O'Shea wrote:
<BLOCKQUOTE TYPE=CITE>&nbsp;<FONT COLOR="#000000">David, with that all
said, I guess I need to slow down my work pace!!!!!! <B>This is a good
thing I guess, because I charge by the hour!!!</B></FONT>&nbsp;When you
and your fingers are killing you from putting them in the holes!&nbsp;Blues
skies,Wayne
<BLOCKQUOTE
style="BORDER-LEFT: #000000 solid 2px; MARGIN-LEFT: 5px; PADDING-LEFT:
5px"><B><FONT FACE="Arial"><FONT SIZE=-1>-----Original
Message-----</FONT></FONT></B>
<BR><FONT FACE="Arial"><FONT SIZE=-1><B>From: </B>David A. Ricker <<A
HREF="mailto:ricker@dbis.ns.ca">ricker@dbis.ns.ca</A>></FONT></FONT>
<BR><FONT FACE="Arial"><FONT SIZE=-1><B>To: </B>Murphy Rebel Builders List
<<A
HREF="mailto:murphy-rebel@dcsol.com">murphy-rebel@dcsol.com</A>></FONT></FONT>
<BR><FONT FACE="Arial"><FONT SIZE=-1><B>Date: </B>Wednesday, March 22,
2000 12:04 PM</FONT></FONT>
<BR><FONT FACE="Arial"><FONT SIZE=-1><B>Subject: </B>Re: [Fwd:
Rivets]</FONT></FONT>
<BR>&nbsp;This is bad, I am not getting any work done!
<P>OK, called AVDEL, they said you want a nice symetric bulb to be formed
<P>Called Rivets Unlimited.&nbsp; They have the rivets we are getting from
Murphy made to their spec.&nbsp; They say that you want a nice symetric
not pull very far into the barrel of the rivet.&nbsp; I described what
they were looking for.&nbsp; The head just pulls into the barrel leaving
edges.
<P>He said that if it is pulled fast/hard enough that the mandrel will
are riveting stops it from stretching radially then the mandrel breaks.&nbsp;
<P>Both Avdel & RU stated that the mandrel was designed to break at
a set <I>static</I> loading.&nbsp; Adding in the dynamic action caused
the rivet barrel.&nbsp; That said, I have seen some variation in the shape
<P>Well folks, there you have it, this is what I have learned this morning,
I hope it is useful and it is presented with that in mind.&nbsp; As with
<P>Back to work now...
<P>Dave R.
<BR>&nbsp;
<BR>&nbsp;
<BR>&nbsp;</BLOCKQUOTE>
</BLOCKQUOTE>
<P>--
<BR>David A. Ricker P. Eng.
<BR>DARTEC Engineering Inc.
<BR>Fall River, Nova Scotia
<BR>Canada, B2T 1E8
<BR>ricker@dbis.ns.ca
<BR>&nbsp;
</BODY>
</HTML>
