fastening method would be O.K. Personally I prefer to rivet for simplicity
and strength. I did chromate all interior surfaces before close up and also
added two drain holes in front of each cross member. That way any
condensation that may build up has a way out and would also ventilate while
flying. Sounds like your making good progress - Bob J - Rebel192/731
Sent: Friday, October 06, 2006 7:49 PM
Subject: [rebel-builders] fuselage cone... inner floor...
Hello!
I am doing the floor channel of the fuselage cone.... When the floor
skin will be fix, the "boxes" will be good trap for humidity!?! Should
make some holes in the channels to let the air circulate? The manual
ask for riveted floor skin... is it ok or is it better to use screw with
tinnerman?
Jean
Rebel 747R
