Yes Tom I would be interested in that tubing for my Moose SR-108. Is
this the design I saw posted just a few days ago on the web-site?
Please contact me at the address below, and we won't have to bother
every one else with our business.
Dick Wampach
rwampach@comcast.net
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com] On Behalf Of
jtpackard@usfamily.net
Sent: Thursday, October 05, 2006 10:51 AM
To:
rebel-builders@dcsol.com
Subject: Re: [rebel-builders] S/M FUS 331 Reinforcement
Bob:
Yes, I did see your design of Fus 331. Nice work. I'm not quite as
ambitious, plus I found a cheap source of the stainless tubing; so, I
tried
to make a simple reinforcement. FWIW, Darryl Murphy commented
positively on
it. If anyone wants to do the same, I can get more of the tubing and
could
supply at cost.
Tom Packard
SR 043
rjohnson18@cogeco.ca>
To: <
rebel-builders@dcsol.com>
Sent: Thursday, October 05, 2006 7:12 AM
Hi Tom: A while ago I posted pictures in SR/Moose landing gear section
titled Redesigned Fus 331. This is a new gear fitting to capture the
top
the gear leg. Very similar to what you are doing except the bolt is
only
subjected to "shear loads". There is a drawing (ACAD) available. We
had
these new fittings made at 1 1/2" wide are an easy bolt in
replacement.
Again, these should compensate for a less then perfect landing. - Bob
J
jtpackard@usfamily.net>
To: <
Sent: Wednesday, October 04, 2006 11:09 AM
Subject: [rebel-builders] S/M FUS 331 Reinforcement
For those interested, I just uploaded a few photos of a modification
made
to my FUS 331 gear mount. I put them in section 124
S/M-Modifications.
It's
an attempt to reinforce the area around the bolt. The one gear
failure we
all saw photos of showed that this bolt sheared through the thinnest
section
of FUS 331 after the failure of the outer gear mount bolt/nut assy.
Most
of us have gone to the next larger bolt AN8 which further decreases
wall
thickness where the failure occurred. I also remember someone
mentioning
that they are seeing some wear/enlargement of this hole with time.
My
belief (hope) is that the steel clamps around this area will minimize
wear
and lesson the chance of catastrophic failure with my less than
perfect
landings.
Regards,
Tom Packard
SR043
List archives located at:
https://www.dcsol.com/login
Unsubscribe:
List administrator:
Checked by AVG Free Edition.
Version: 7.1.407 / Virus Database: 268.12.12/462 - Release Date:
10/3/2006
http://USFamily.Net/dialup.html - $8.25/mo! --
http://www.usfamily.net/dsl.html - $19.99/mo! ---
Unsubscribe:
List administrator:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
