[rebel-builders] Pneumatic Cleco Pliers
apoulsen
Post by apoulsen » Sun Feb 19, 2012 11:13 am
Wayne,
The fellows on the RV-10 list like this one...
http://www.yardstore.com/index.cfm?acti ... ategory=88
Allen Poulsen
786R
To: "Murphy Rebel Builders List" <rebel-builders@dcsol.com>
Sent: Wednesday, September 27, 2006 3:59 PM
Subject: [rebel-builders] Pneumatic Cleco Pliers
After three + months of staying away from alum work and now finally being
able to sleep through the night without forearms/hands
throbbing/sleeping.....I don't want to be back in the same boat this
winter
as I prepared to tackle another fuselage build.
What model of Pneumatic pliers are you using and where did you get them??
Dave Ricker
Post by Dave Ricker » Sun Feb 19, 2012 11:13 am
LOL! you getting soft in your old age? ;-)
They can be had at ACS but we built ours, go to other details at
www.elite583.cjb.net for a photo.
throbbing/sleeping.....I don't want to be back in the same boat this winter
David A. Ricker
Fall River, Nova Scotia
Canada
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:13 am
Yes Dave! 13 years of full time cleco/drilling/deburring has definitely
taken it's toll!
Sent: Wednesday, September 27, 2006 4:26 PM
Subject: Re: [rebel-builders] Pneumatic Cleco Pliers
winter
David A. Ricker
Canada
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 11:13 am
I just ordered one so I'll give the list a first-hand report in a few days
when I receive it.
apoulsen
Sent: Wednesday, September 27, 2006 2:17 PM
Wayne,
Allen Poulsen
786R
winter
Jean Poirier
Post by Jean Poirier » Sun Feb 19, 2012 11:13 am
Hello Wayne
The pneumatic cleeco plier that is sale by "The Yard Store"
(http://www.yardstore.com/index.cfm?acti ... ategory=88)
is the one that I use since 18 months (1-1/2 wing!). With a very soft
polyurethane hose, it is a wonderful tool when you have to remove a lot of
cleeco...
Jean
Rebel 747R
Jean Poirier
Pr
another question to everyone...do you find they wear out the cleco springs
from full stroking the mechanism of the cleco. Ie..do you have any clecos
that no longer pull tight?
From: "Jean Poirier" <jean.poirier@oxyportneuf.com>
Sent: Wednesday, September 27, 2006 4:56 PM
[quote]Hello Wayne
cleeco...
Jean
Rebel 747R
Jean Poirier
Pr
Post by Ken » Sun Feb 19, 2012 11:13 am
Yup if I don't use the pneumatic puller from Spruce, it is the same
symptoms as operating the chainsaw for too long, and I get real grumpy
without my sleep! The puller needs a drop of oil occasionally, same as
the pneumatic drill, or it starts to bind up and not fully release the
cleco for removal. It needs about 90 psi to fully pull but I have an
additional air line restrictor to slow it down a bit so it doesn't hit
the work quite so hard when removing clecos. It doesn't pull the clecos
any tighter than I do by hand so I don't believe it has any detrimental
effect on cleco life. Did you leave any fish left up there for next
year Wayne ? ;)
I had some fun and expanded the flight testing a bit this morning. A
windmilling 3 blade Warp prop seems to be a fair bit of drag at cruise
speed on 119R as expected, but at 60 knots there is surprisingly little
difference in descent rate between slow idle (600 prop rpm with closed
throttle) and a stopped prop. Some airplanes glide significantly farther
with a stopped prop but apparently mine is not one of them.
taken it's toll!
winter
Thanks...I just tried ordering both models from The Yard (even got an order
confirmation) and then got a phone call minutes ago to be told I amazed them
that I was able to put the linked $24.95 pistol grip tool into my shopping
cart. Apparently they removed it, no more stock, from their website days
ago. I wanted one of each style to see which worked best ergonomically. Oh
well, gotta be better than what I have now and I think a well spent $64.95
(that I probably should have spent 10 years ago!!)
Lots of fish left Ken...didn't get out a lot and when we did not much was
caught.
Did you stop it on purpose is the question? :O)
Sent: Wednesday, September 27, 2006 6:00 PM
year Wayne ? ;)
taken it's toll!
Yup stopped it on purpose. No big deal with an instant starting EFI car
engine and kind of fun to be in a glider for awhile ;)
Funny part was that I climbed high while heading to a grass strip for
the excercise then realized that a North South strip wasn't going to be
much good with a 20 knot wind from the West...
At first I thought a pistol grip cleco puller would be more ergonomic
than mine. However when working on horizontal surfaces I hold it the
same way I'd hold a bottle of beer and all is comfortable ;)
caught.
year Wayne ? ;)
Post by Drew Dalgleish » Sun Feb 19, 2012 11:13 am
Hi Ken I don't think you should ever use the term significant glide when
refering to any rebel :)
Unfortunately the model they have none of anymore!
Sent: Saturday, September 30, 2006 6:52 PM
I purchased one of these and got it yesterday. Works really, really well.
Beats the crap out of the manual pliers. I can insert cleco's much faster
and take them out maybe 5 times faster. Best $25 I ever spent...well,
except for the last case of beer that is...
apoulsen
Wayne,
Allen Poulsen
786R
winter
