[rebel-builders] Rebel - Elevator and Rudder Bend Reinforcem
[rebel-builders] Rebel - Elevator and Rudder Bend Reinforcement
Post by Bob Patterson » Sun Feb 19, 2012 11:12 am
Hi Rich !
No worries ! Never seen a problem on Rebels.
I'm assuming you have done the L doubler on the outside elevator
ribs, as well as the semi-circle doubler above those ribs, under
the skin....
You already know about hand-pulling the end rivets, if necessary,
to clear the rivets on the other side - slowly, with a bit of an angle
until started. Same as on the ailerons.... although, you could
just drill new holes with separation ...
On Thursday 21 September 2006 07:05 pm, Rich Dodson wrote:
Gents,
I am getting ready to close up the rudder and the right elevator. A friend
mentioned that RVs used to have a problem with cracks along the trailing
edges of the ribs near the bend in the skin. Has this ever been a problem on
a Rebel?
Thanks for the help!
Rich Dodson
Virginia Beach, VA
Rebel 806
