Don't forget to add a hole at the rear of that tight new rib,
so the water can drain out ! :-)
On Friday 22 September 2006 03:29 pm, Rich Dodson wrote:
so far, and have done all the doubling that my predecessors have recommended.Thanks Bob, Eric, and Drew!
Progress is in progress here in Virginia. I am pretty pleased with my work
The couple of edge distance violations I have will be doubled to ensure
integrity. I am certainly learning alot about metal!
rudder) rib on the elevators. I just did not like the look of the suppliedI also took the time to make a longer rib for the inner most (nearest the
rib when it came in at 1.25 inches short with two holes on the elevator
trailing edge left open. It took about 20 hours to get it right but getting
a nice and tight fit was the reward.
wonderful guys on this list to help!I am fortunate to have some experienced builders at my airport and you
THANK YOU!
Rich
Rebel 806R
